3 encoder reading and serial transmition
aeroboy
PostPosted: Thu Apr 30, 2009 7:19 pm     Reply with quote
I made a code to read three differential encoders, save the increments each one does and send that increments to other pic every 6.3 ms via serial comunication. Also I am recieveing data. Since I have three encoders what I think I could do is to read the encoders as fast as possible. The problem its that I am losing data. The encoders have a resolution of 1200 per revolution. Is there a way to fix the loss of data or I had better change to absolute encoders?
Thanks.
--Luis
#include <16F877A.h>
#include <stdlib.h>
#define LED PIN_C4
#use rs232(baud=57600, xmit=PIN_C6, rcv=PIN_C7)
#byte PORTB=0x06 //Define PORTB in memory location
#byte PORTC=0x07 //Define PORTC in memory location
#byte PORTD=0x08 //Define PORTD in memory location
#byte TXREG=0x19 //Define TXREG in memory location
#byte RCREG=0x1A //Define RCREG in memory location
unsigned char dirp,diry,dirr; // Direction of each sensor
struct VBITS{   // structure with the values of the encoders
    unsigned char uA:1;    //UnusedA
    unsigned char uB:1;    //UnusedB
    unsigned char pA:1;    //PitchA
    unsigned char pB:1;    //PitchB
    unsigned char yA:1;    //YawA
    unsigned char yB:1;    //YawB
    unsigned char rA:1;    //RollA
    unsigned char rB:1;    //RollB
unsigned char CHANN;
#INT_RDA // Recieve interrupt
void RS232C_Recieve_Interrupt()
   CHANN=RCREG;
//   delay_us(20);
   PORTD=CHANN;
//   delay_us(20);
signed char CHANN2,PWMX2; // Variables to send data
signed char PitchCnt; // Variables to count positions
signed char YawCnt;
signed char RollCnt;
short flag=1;
#INT_TIMER1 // Timer 1 Interrupt
void Timer1_Interrupt()
   flag=~flag;
   set_timer1(0xF09F); // Initializes timer1
   // Send Channel or encoder
   if(CHANN2==PWMX2) // If equal send convertion
      if(PWMX2==123)
            TXREG=PitchCnt;
         PitchCnt=0; // Send Pitch to PIC 3
      if(PWMX2==124)
            TXREG=YawCnt;
         YawCnt=0; // Send Yaw to PIC 3
      if(PWMX2==125)
            TXREG=RollCnt;
         RollCnt=0; // Send Roll to PIC 3
      ++CHANN2; // Increment channel
      if(CHANN2>125)
         CHANN2=123;
      TXREG=CHANN2; // Send value to PIC 1
      PWMX2=CHANN2; // Update channel
int a;
struct VBITS TEMP;
struct VBITS OLD;
a=1;
   set_tris_c(0b11000000); //PWM1 & 2 Output
                     //LED PORT Output
                     // USART TX & RX
   set_tris_b(0xFF); // Port B all Input
   set_tris_d(0x00); // Port D all Output
      // clock source=internal=clock/4=5 MHz
      // overflow at every 1 / 5MHz * ( 2^16 - 0xF09F ) = 0.0007874 sec
      // prescaler = 8                  | 3937 |
      // interrupt every 0.0001874 * 8 = .0062992 sec
   enable_interrupts(INT_RDA); // Enable recieve interrupt
   enable_interrupts(INT_TIMER1); // Enable timer1 interrupt
   output_high (LED); // Turn on LED
   YawCnt=0;    // Initialize variables
   PitchCnt=0;
   RollCnt=0;
   OLD=PORTB;
   TEMP=OLD;
   CHANN2=123;
   PWMX2=0;
   while(a==1)
      TEMP=PORTB; // Save Actual Sensor Value
        /*F O R   P I T C H*/
      if ((OLD.pA != TEMP.pA) && (OLD.pB != TEMP.pB)){
         if(dirp==1) PitchCnt=PitchCnt+2;
         if(dirp==0) PitchCnt=PitchCnt-2;
       else{
         if ((OLD.pA != TEMP.pA) || (OLD.pB != TEMP.pB)){
            if (TEMP.pA == OLD.pA){
               if (TEMP.pB == TEMP.pA){
                     --PitchCnt;
                  dirp=0;
                  else{
                     ++PitchCnt;
                  dirp=1;
              else{
                     ++PitchCnt;
                  dirp=1;
                  else{
                     --PitchCnt;
                  dirp=0;
      /*F O R   Y A W*/
      if ((OLD.yA != TEMP.yA) && (OLD.yB != TEMP.yB)){
         if(diry==1) YawCnt=YawCnt+2;
         if(diry==0) YawCnt=YawCnt-2;
      else{
         if ((OLD.yA != TEMP.yA) || (OLD.yB != TEMP.yB)){
               if (TEMP.yA == OLD.yA){
                  if (TEMP.yB == TEMP.yA){
                     --YawCnt;
                  diry=0;
                 else{
                     ++YawCnt;
                  diry=1;
               else{
                     ++YawCnt;
                  diry=1;
                  else{
                     --YawCnt;
                  diry=0;
        /*F O R   R O L L*/
         if ((OLD.rA != TEMP.rA) && (OLD.rB != TEMP.rB)){
         if(dirr==1) RollCnt=RollCnt+2;
         if(dirr==0) RollCnt=RollCnt-2;
      else{
            if ((OLD.rA != TEMP.rA) || (OLD.rB != TEMP.rB)){
               if (TEMP.rA == OLD.rA){
                  if (TEMP.rB == TEMP.rA){
                     --RollCnt;
                  dirr=0;
                  else{
                     ++RollCnt;
                  dirr=1;
               else{
                     ++RollCnt;
                  dirr=1;
                  else{
                     --RollCnt;
                  dirr=0;
   OLD = TEMP; // Update Old Sensor value
