Question about kbhit() and fgetc(stream)
cchappyboy
PostPosted: Thu Apr 30, 2009 10:54 am     Reply with quote
I use pic18f458 and set 2 uart port
#use rs232(baud=2400,xmit=tx_1,rcv=rx_1,stream=g)
#use rs232(baud=9600,xmit=tx_2,rcv=rx_2,stream=d)
I want to use stream d to receive data
int timed_getc(long m,int n)
  long timeout=0;
  while(!kbhit(d)&&(++timeout<m)) //if m=100 n=10 wait untill 1ms
      delay_us(n);
   if(kbhit(direct))
         return(fgetc(d));
       return(0);
   while(true)
      rec=timed_getc(100,10);
           fprintf(direct,"%C\n\r",rec);
The input stream is like
AB-DEFG123.123 ASGDS123.12345crlf
I can not get right output.
I appreciate help.
PostPosted: Thu Apr 30, 2009 12:37 pm     Reply with quote
What pins are used for "tx_1", etc.
Post those two lines with the actual CCS pin number constants.
cchappyboy
PostPosted: Thu Apr 30, 2009 6:22 pm     Reply with quote
#define tx_1 pin_c6
#define rx_1 pin_c7
#define tx_2 pin_c0
#define rx_2 pin_c1
In main()
indicate
int rec=0;
Wayne_
PostPosted: Fri May 01, 2009 2:05 am     Reply with quote
Shouldn't this line
if(kbhit(direct))
be
if(kbhit(d))
Where is direct defined ?
cchappyboy
PostPosted: Fri May 01, 2009 6:42 am     Reply with quote
yes, direct should be d.
it is just mistake when i post in here.
Wayne_
PostPosted: Fri May 01, 2009 6:50 am     Reply with quote
If there is a gap of 1sec in the data stream your function will return 0 which you still print out. This char may mess up your output so it looks like something is wrong when it isn't.
Try putting a check in
if (rec != 0)
  fprintf(direct,"%c\n\r",rec);
I noticed you are using an upper case C in the printf statement. Case does matter and the normal form displaying a char is a lowercase c. Not sure how CCS would handle this.
