aeroboy
signed char and signed long |
Posted: Tue Apr 28, 2009 5:36 pm |
Does the CCS compiler support a signed char subtraction from a signed long?
signed long x;
signed char y;
x=989;
y=-45;
x=x+y;
x=944
I do not have a way to verify this but I need it to know how to do the code.
Thanks.
--Luis |
Posted: Tue Apr 28, 2009 5:49 pm |
Quote: | I do not have a way to verify this |
Do you have the CCS compiler and MPLAB ? If so, you have the power
to make a test program and run it in the MPLAB simulator. Configure
the simulator to display printf() text in the Output Window.
Instructions on how to do this:
http://www.ccsinfo.com/forum/viewtopic.php?t=23408&start=1
Here's the output of the following program:
Here is the test program:
Code: | #include <16F877.H>
signed long x;
signed char y;
x=989;
y=-45;
x=x+y;
printf("%ld", x);
SherpaDoug
Posted: Tue Apr 28, 2009 5:51 pm |
Standard C rules say it should promote Y to a long and then do the math. I would be astonished if CCS could not handle this automatically. _________________ The search for better is endless. Instead simply find very good and get the job done. |
