Low frequency counter
snooer
PostPosted: Mon Apr 27, 2009 6:45 am     Reply with quote
#include <16F877a.h>
//#fuses XT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP,NOWDT
#include <stdlib.h>
#include <lcd.c>
#include <ctype.h>
#include <1wire.c>
#include <ds1820.c>
#define XTAL_FREQUENCY  8000000
#define TIMER1_FREQUENCY (XTAL_FREQUENCY / 4)
#bit t1_overflow=0x0C.0
// #bit t1_overflow=0xF9E.0  (PIC18, Reminder)
   int cycles8, cycles;
   int32 freq;
   long freqc_high;
   long freqc_low;
 float temp;
   while (TRUE) {
      cycles8=0;
      cycles=0;
      freqc_high=0;
      t1_overflow=0;
      setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
      set_timer1(0);
/* ___ wait one second ___  */
      while (cycles!=0xFF) { //true=3, false=4
       cycles8=0; //1 cycle
       //start inner loop
       while (cycles8!=0xFF) { //true=3, false=4
         if (t1_overflow)//true=2,false=3             //----|
            {t1_overflow=0;freqc_high++;}//6 cycles   //    |
         else                                         //    |-- 8 cycles
            {delay_cycles(5);}                        //----|
         delay_cycles(63); //x
         cycles8++; //1
 ///2 cycles to jump to top
 //math: end inner loop
 //math: total inner loop=((3+8+x+1+2)*255 + 4)*255
 //math: if x=62.87781 then inner loops takes 5mil instructions
 //math: if x=62 then inner loop takes 4942920, have to fill 57080 cycles
 delay_cycles(218);      //y
 cycles++;          ///1 cycle
 ///2 cylces to jump to top
 //math: outer=(3+1+y+1+2)*255+4=57080
 //math: y=(57080-4)/255)-(3+1+0+0+1+2)
 //math: if y=216.827450980392156862745098039216 then outer loop cylces is 57080
 //math: if y=216 then outer loop cycles is off by 211 cycles.  z=211
      delay_cycles(211);   //z
/* ___ end waiting 1 second ___ */
      setup_timer_1(T1_DISABLED);//turn of counter to prevent corruption while grabbing value
      temp = ds1820_read();
      if (t1_overflow)            //check one last time for overflow
      freqc_high++;
      freqc_low=get_timer1();      //get timer1 value as the least sign. 16bits of freq counter
      freq=make32(freqc_high,freqc_low);//use new make32 function to join lsb and msb
      lcd_init();
      printf(LCD_putc "Speed:%Lu Hz\r\nTemp: %3.1f%cC ",freq,temp,223);      //and print frequency
The problem is that I need low frequency counter. I used a freqc.c example but it show 0. Then freq is 1 and 1-2 then freq is 2. Any solution to solve this problem?
