writing counters
bling23
writing counters
PostPosted: Fri Apr 24, 2009 11:45 am     Reply with quote
hi everyone,
i'm trying to make the program run through a particular code for a set number of times.
is there something wrong with doing it this way.
i want it to look at sensor 1 for a set number of times and then look at sensor 2.
but it seems like when i am compiling it says condition is always true for the for loops
can someone explain?
void
main(void) {
  int n;
  init();
  port_c=0x00;
  putc(1);
  delay_ms(2000);
  clear_display();
  for (n=0 ;n<500 ;n++ ) {
        monitor_distance_sensor1();
  for(n=0;n<500;n++){
           monitor_distance_sensor2();
treitmey
PostPosted: Fri Apr 24, 2009 11:49 am     Reply with quote
in CCS an int is 8bits. max value 255
Change int to int16
see if that works. Smile
bling23
PostPosted: Fri Apr 24, 2009 11:52 am     Reply with quote
wow! haha i totally forgot about that. is there anyway i can make it count higher?
snooer
PostPosted: Fri Apr 24, 2009 12:09 pm     Reply with quote
int1 0 to 1
int8 0 to 255; -128 to 127
int16 0 to 65535; -32768 to 32767
int32 0 to 4294967295; -2147483648 to 2147483647
float32 -1.5 x 1045 to 3.4 x 1038
