A/D converter performance..... |
Posted: Tue Apr 21, 2009 9:46 pm |
Hi All,
I'm working on a project that uses a PIC16F876A to read and display (on a GLCD) the output voltage and current of a benchtop power supply. I've got the A/D in 10 bit mode, and I have successfully measured and displayed these values. I'm looking to make a (relatively) precise piece of measurement equipment, but so far I'm not impressed with the internal A/D converter. For example, I've got an adjustable "scale factor" for each reading type, and when measuring voltage, I adjust it to read correctly at 20V (for example), the readings will be off by 50mV at 10V. I haven't taken a lot of data yet, but this is certainly more than I expected I don't think it's anything else because I'm using 0.1% resistors in my voltage divider, and values, 66.5K, and 15K, that are sufficiently high that there should be minimal interaction with the A/D input itself.
Anyway, what have others found about the internal A/D converter? Is a single correction factor enough, or do I need to do more? Some sort of a polynomial correction, or a lookup table? How about an external A/D, would the performance be better in terms of these gain errors that i appear to be seeing?
Doug |
Matthew Aurand
Posted: Tue Apr 21, 2009 10:25 pm |
There are several factors that contribute to the performance of the ADC unit.
The basics for DC measurement include things like...
1. ADC Driver Stage: You want to drive the ADC input with a low-noise, low-impedance source. High-value resistive dividers are generally a no-no, but in low-speed applications probably OK. When selecting a buffer op-amp, low voltage offset and noise are good things to look for (gets more complicated for AC measurements).
2. ADC Voltage Reference: Stability and noise performance are critical features. If a precision device is desired, an external voltage reference is almost a must - the power supply is usually more prone to fluctuations and noise.
3. ADC Power Supply: Low-noise supply is required for high-performance digitization (although in 10-bit systems you don't have to be terribly concerned with this).
Hope this helps a bit. You can get better results from an external converter (better linearity & resolution) but you have to be very careful with the above 3 factors as resolution increases. _________________ -Matthew A. Aurand |
Posted: Tue Apr 21, 2009 10:39 pm |
Post a very short test program, so we can look at your ADC clock divisor,
delay after channel change, and your math operations.
The program should have the #include, #fuses, #use delay, and any
other necessary #use statements. It should have a main(), etc., and
it should compile with no errors. Also post your compiler version.
Run the program on the actual hardware to verify that it shows the
problem. Then post it. |
Posted: Wed Apr 22, 2009 8:58 am |
Hi All,
Here is a short test program that compiles fine with v4.050. I've stripped out everything but the A/D routines, and a code to send the result to a terminal display.
#include <16F876a.h>
#device ADC=10
#fuses HS, NOWDT, NOPROTECT, NOPUT, NOLVP
#ROM 0x2100={191,103} //Voltage with scale of 2656
//-----< General Pin Assignment Defines >-----
#define Tx_Out Pin_B1 // serial data transmit pin to PC
//-----< Serial Port Definition >-----
#use rs232(baud=9600, xmit=Tx_Out, stream = Console)
// Here we read the ADC 8 times, take the average, and return the result
long read_adc_average()
long value;
int i;
//set_adc_channel(A/D_Input);
set_adc_channel(0);
delay_ms(150);
value=0;
for ( i=0 ; i<8 ; i++ ) {
value += read_adc();
delay_ms(10);
/* divide by 8 */
value = value / 8;
return value;
int16 VoltsScaleFactor;
int32 ScaledReading;
VoltsScaleFactor=make16(READ_EEPROM(1), READ_EEPROM(0));
// Here we setup the PIC hardware peripherals
setup_adc_ports(AN0);
//Here we used 'scaled integers' to avoid memory hungry 'float' operations. The correct 'display' value is shown
//by scaling the A/D reading, and then correctly positioning the decimal point.
//'5000000' = 5.000 on the GLCD display, so we divide this number by 1023 (max output of 10 bit A/D) to
//obtain the ScaleFactor. 5000000/1023 = 4888, which we convert into binary (1001100011000), and then
//into two separate 8 bit words (0:24d, 1:19d)
//Note: Voltage is measured with a 66.5K and 15K divider (0.184 ratio). With 20V applied to the divider, the output
//will be 3.68V. Also, the output of the divider will be 5.00V when 27.17V is applied. Therefore the scale needs to
//be 27170000/1023 = 26559, which we convert to binary (1100111 10111111), and then into two separate 8 bit words
//(0:191d, 1:103d)
//Here we read the A/D converter, and display the appropriate reading on the LCD.
ScaledReading=((int32)read_adc_average()*VoltsScaleFactor)/1000;
// Here we send the reading to the serial port
fprintf(Console, "%04.3w\n\r", ScaledReading);
delay_ms(250);
Thanks,
Doug |
Posted: Wed Apr 22, 2009 10:17 am |
Quote: | #include <16F876a.h>
#device ADC=10
setup_adc(ADC_CLOCK_INTERNAL); |
Read this section of the 16F876a data sheet:
Quote: | 11.2 Selecting the A/D Conversion Clock |
With a 20 MHz oscillator, the recommended A/D clock divisor is 32. |
