UART How do you change parity or data len within program
sraiderk
PostPosted: Thu Apr 23, 2009 8:08 am     Reply with quote
I want to adjust the following HARDWARE UART setting when pic at energized. For example; pic internal eeprom has the following values. I want to read this values from internal eeprom then I want to adjust hardware uart setting according to these read values from eeprom. This process is only active when pic at energized. After that I don't need any uart setting when pic run. Is it possible?
Uart_speed (example:9600)
Uart_parity (Example:Odd)
Stop_bit_length (Example:1,5)
Data_bit-length (Example: 7 or 8)
main()
int x;
  x=read_internal_eeprom(0);
  switch(x)
    case 0:
              #use rs232(baud=9600,parity=E,xmit=PIN_C6,rcv=PIN_C7,bits=8)
       case 1
              #use rs232(baud=9600,parity=O,xmit=PIN_C6,rcv=PIN_C7,bits=7
       case 2
              #use rs232(baud=19200,parity=n,xmit=PIN_C6,rcv=PIN_C7,bits=9
 while(true)
Is it possible?
treitmey
PostPosted: Thu Apr 23, 2009 8:25 am     Reply with quote
See Neutone post (bottom)
http://www.ccsinfo.com/forum/viewtopic.php?t=22062
