| Termination of Rx pin? |
Posted: Mon Apr 20, 2009 2:29 pm |
I'm working on a desgn that implements a serial port for configuration and parameter updating. Since this feature is seldom used, the board will not have a MAX232 interface IC on it, but simply a header with the required signals. An adapter cable with a MAX232 will be used with the board when required.
My question is what, if any, termination do I need on the Rx input to the PIC? Should I include a 10K pulldown to avoid noise pickup?
Chas |
Posted: Mon Apr 20, 2009 2:40 pm |
| Quote: | | Should I include a 10K pulldown to avoid noise pickup? |
For the hardware UART, the idle state is a high level. |
Posted: Mon Apr 20, 2009 3:09 pm |
Hi PCM,
Meaning what then? It's OK to leave floating, or I need to add a pull-up instead of a pull-down?
Chas |
Posted: Mon Apr 20, 2009 3:11 pm |
| Put a 10K pull-up on it. |
Posted: Mon Apr 20, 2009 5:42 pm |
Hi PCM,
You made the distinction of a hardware UART, so does that mean that a software UART input would require the pull-down?
Chas |
Posted: Mon Apr 20, 2009 5:49 pm |
The software UART can be configured for normal or inverted mode
(with the 'INVERT' paramter in the #use rs232 statement).
If the inverted mode is used, the idle state is a low level and a
pull-down resistor would be used on the Rx pin. |
