Simulate PIC24F - ISIS 7.4 -CCS, is possible?
xlaz1078
PostPosted: Sat Feb 14, 2009 10:15 am     Reply with quote
Smile Hi, I'm new to PIC24, and before I buy some cards of development, I have tried to simulate the 24FJ64GA004 (EX_PinSelect.C - PCWHD 4.084) with ISIS PROTEUS 7.4 SP3. What I got many errors Rolling Eyes .
It is possible to use CCS PWD + ISIS + PIC24F? Confused
leejok2003
PostPosted: Tue Feb 17, 2009 7:19 am     Reply with quote
Hi xlaz1078,
what kind of error you have there?
xlaz1078
PostPosted: Sat Feb 21, 2009 7:03 am     Reply with quote
for the delay, this is a segment of the simulation:
http://oat8gw.blu.livefilestore.com/y1pT7wg2hhhBJeV0WLfZ8iefnZjaeBZArT0OkztgPQnnUAY1lhhvEQMuNOG9QIcbUW1N9UYz8LocO1G6c6X_iOSSQ/problem.jpg
radioamator
PostPosted: Fri Apr 17, 2009 3:28 pm     Reply with quote
hi
i have same problem with ccs and proteus when simulate my hex file with proteus this error"write 0xffff to unimplemented memory address 0x32a cause a trap"
i have this problem with mplab simulator too
anybody know solution for this problem
excuse me for bad english
PostPosted: Fri Apr 17, 2009 3:58 pm     Reply with quote
If you expect any help, you should show the code lines causing the error trap.
P.S.: If I remember right, the said 0x32a error trap issue has been already discussed in the forum before. It's caused by erroneous SFR accesses of PCD built-in ADC functions. They are accessing register AD1PCFGH, that is only present with larger PICs. I found, that the bug is still present with PCD V4.090 and PIC64FJ64GA004. Cause an access to the register is used in chip setup, even with no ADC functions used in the code, I don't see an easy workaround.
