usart 16F877A
volcane
usart 16F877A
PostPosted: Sun Apr 19, 2009 3:46 pm     Reply with quote
Hi!
I am using a PIC16F877A, as possible checking RCIF? as you are reading RCREG?
PostPosted: Sun Apr 19, 2009 3:54 pm     Reply with quote
Make a test file. Set the List file format for "Symbolic". Compile the
file and look at the .LST file to see the generated ASM code.
Look at the .LST file below. The kbhit function tests the RCIF bit. The
getc() function also tests the RCIF bit (in a loop) and if it is True, then it
reads the RCREG register.
... if(kbhit())
0015:  BCF    STATUS.RP0
0016:  BTFSS  PIR1.RCIF   // Test the RCIF bit
0017:  GOTO   01C
.... c = getc();
0018:  BTFSS  PIR1.RCIF
0019:  GOTO   018      // Stay in a loop until RCIF == 1
001A:  MOVF   RCREG,W  // Then read RCREG
001B:  MOVWF  c
Here is the test program:
#include <16F877.H>
int8 c;
int8 status;
if(kbhit())
   c = getc();
volcane
PostPosted: Sun Apr 19, 2009 4:07 pm     Reply with quote
Hi!
thanks
without you i do not know how to do :-)
