DS18B20 initializes but doesn't measure.
bolke
PostPosted: Thu Apr 16, 2009 5:58 am     Reply with quote
I'm using pic18f2420 in combination with a DS18B20.
I've searched the forums and I've found a whole lot of
examples, except they don't work. Probably a small problem,
but I'm not seeing it.
The DS18B20 is connected in normally powered mode.
I'm able to read the scratchpad and write a configuration
value in it.
Except when I want to read a temprature value, it doesn't
work. I'm only getting the default 0x50 and 0x05 values that
are in the MSB and LSB of the temprature. So it isn't a formatting
error.
It seems like the chip is skipping the temprature convert command, not pulling the line low while reading temprature.
The pin used is PIN_B7. This one is #defined as TEMP.
Ccs version: 4.068
Fuses:
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES PUT                      //Power Up Timer
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
The code:
void tmp_reset(){
  output_low(TEMP);
  delay_us(480);
  output_float(TEMP);
  delay_us(480);
void write1(){
  output_low(TEMP);
  delay_us(2);
  output_float(TEMP);
  delay_us(62);
void write0(){
  output_low(TEMP);
  delay_us(60);
  output_float(TEMP);
  delay_us(2);
void tmp_write(int8 value){
  int i;
  for(i = 0; i < 8; i++){
   if (shift_right(&value,1,0))
     write1();
     write0();
int8 tmp_read(){
  int i;
  int result = 0;
    output_low(TEMP);
    delay_us(2);
    output_float(TEMP);
    delay_us(8);
    shift_right(&result,1,input(TEMP));
    delay_us(120);
  return result;
float tmp_read_temp()
 int i;
int busy=0, temp1, temp2;
signed int16 temp3;
 float result;
 output_float(TEMP);
 tmp_reset();
  tmp_write(0xCC); // skip rom
  tmp_write(0x44); // get temprature;
  output_float(TEMP);
  while(!tmp_read()); // wait till pullup
  tmp_reset();
  tmp_write(0xBE); // read sketchpad
  for(i = 0; i < 9; i++){
    printf("*1value1:%u*\r\n",tmp_read()); // print it
  tmp_reset();
  return 0;
And a main.
void init(){
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);       setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_XMIT_L_TO_H|SPI_CLK_DIV_16);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_8 );
   setup_vref(FALSE);
   set_timer1(25000);
   enable_interrupts(INT_RDA);
   disable_interrupts(INT_TIMER1);
  init();
  while(true){
      tmp_read_temp();
      delay_ms(10);
PostPosted: Thu Apr 16, 2009 6:27 am     Reply with quote
For start I'd say clean up your code. There is so much temporary test code present that I don't want to spend time looking into it. For example:
void tmp_reset(){
  output_low(TEMP);
  delay_us(480);
  output_float(TEMP);
  delay_us(60);
  //printf("#low[%u]*\r\n",input(TEMP));
  delay_us(15);
  output_float(TEMP);
  delay_us(180);
  output_float(TEMP);
is equivalent to:
void tmp_reset(){
  output_low(TEMP);
  delay_us(480);
  output_float(TEMP);
  delay_us(255);
Post a cleaned up and complete test program including main and #fuses.
Post your compiler version number.
bolke
PostPosted: Thu Apr 16, 2009 9:09 am     Reply with quote
Code has been cleaned, and information added, as per request.
PostPosted: Thu Apr 16, 2009 12:00 pm     Reply with quote
I'm not at home so can't run the code in a simulator but I don't see any obvious errors.
The code as posted contains a syntax error making it not the exact same code as you have tested with...
Double check you are using the DS18B20 and not the DS18B20P. The Parasitic power version apparently gives the same results you are seeing.
http://www.ccsinfo.com/forum/viewtopic.php?t=28425&start=17
Note: are you sure to need the LVP fuse? 99% of the programmers are high voltage types. If you are not using an LVP-programmer set the fuse to NOLVP to avoid problems with the processor resetting on voltage spikes on pin B5.
bolke
PostPosted: Fri Apr 17, 2009 2:25 am     Reply with quote
It's a DS18B20 , at least as far as I can see. On the chip it
says: DALLAS DS18B20 0838C3 +161AE.
A normal DS18B20 it seems.
I've removed the fuse, I'm not using it indeed.
Syntax error also removed. A bit of an copy paste error.
PostPosted: Fri Apr 17, 2009 9:37 am     Reply with quote
The DS18B20-PAR is clearly marked as a DS18B20P. You have the normal DS18B20.
Don't remove the LVP fuse but replace it by NOLVP. I'm not sure what the default value is so I always like to make these settings specific.
Try replacing the line:
by
while (tmp_read() == 0xFF);  // wait till pullup
This is the opposite of most example code I see here in the forum. Maybe someone else can confirm this to be correct? In the Proteus simulator the posted code works with this change.
bolke
PostPosted: Mon Apr 20, 2009 1:17 am     Reply with quote
Nope, not working.
The chip still returns the 0x50 / 0x05 values.
I'll see if I can get another chip, maybe that this
one's half-dead.
If there's anyone out there witha ds18b20, could
you confirm that the code above works? (as in
reads a temprature, not compile works Wink ) ...
