Length of string TCP/IP?
Tagge
PostPosted: Wed Apr 15, 2009 8:37 am     Reply with quote
Hi, does anyone know the default length of the string in:
int8 http_format_char(int32 file, char id, char *str, int8 max_ret)
Length of max-ret? = size of *str.
And how can I make it bigger? or isn't it possible?
How could I then put out a longer string, for ex 256 chars, at the web page?
Right now I can only display about 25 chars at the time, and I have tried to increase the buffer inside the function, but its the max_ret that keeps it short. If I use the true length (len) of the string it can show once and the whole string, but then the web side crashes.
if (len){
        strncpy(str,new_str,len);
        //strncpy(str,new_str,max_ret); //original
   }else
      *str=0;
Thanks/Tagge
PostPosted: Wed Apr 15, 2009 12:20 pm     Reply with quote
Get a text search program and search for that function name.
This will tell you what file is calling that function. Then look at the
variable declarations above the call. You will see size of the array.
Then you can edit it to be longer.
I searched for "http_format_char" and it's called by these files,
at a minimum:
c:\program files\picc\projects\ccstcpip\tcpip\http.c
c:\program files\picc\tcp-ip\pic examples source\drivers\http.c
c:\program files\picc\tcp-ip\pic examples source\tcpip\http2.c
Tagge
PostPosted: Thu Apr 16, 2009 2:39 am     Reply with quote
Hi, found it out.. if you want 200 chars for ex.
is in the file http.c
and the following function:
int1 tcp_http_put_file(int8 which, int16 errorCode, int32 file, char *contentType)
and the change to be made is:
static char str[200];//changed from 40
Thanks/Tagge
