Find the lowest value in the EEPROM
Pichuqy_1
PostPosted: Tue Feb 08, 2011 10:13 pm     Reply with quote
I need to find the address of the PIC internal EEPROM, Which contains the Lowest value and I can not write the code. Could you help me get started. Thank you very much. Embarassed
PostPosted: Tue Feb 08, 2011 10:41 pm     Reply with quote
Use a for() loop to read all the values in the eeprom memory.
This post should give you some ideas of how to do the testing:
http://www.ccsinfo.com/forum/viewtopic.php?t=41229
Pichuqy_1
PostPosted: Wed Feb 09, 2011 8:49 pm     Reply with quote
Hi PCM programmer. Thanks for the help. My program was well. If you have any improvements you would appreciate it.
// This subroutine finds and stores the address of the lowest value in the
// EEPROM area.
void Get_And_Store_Low_Value_Address(void)
int direccion,direccion_lowest,z;
float current,lowest;
direccion = 8;
z=0;
lowest = 0xFFFF;
for(z=0; z<=15; z ++){
current = read_float_eeprom(direccion);
if(current < lowest){
lowest = current;
direccion_lowest =  direccion;                  }
direccion = direccion + 4;
delay_us(50);
write_int16_eeprom(72, direccion_lowest);
delay_us(50);
