What is that somebody has an example of program of use of the RS485 library.
Thank you,
Posted: Sun Feb 29, 2004 4:56 pm
If you have the CCS compiler, look in the
drivers folder for the RS485.C file:
c:\program files\picc\drivers\rs485.c
zagoaristides
Joined: 08 Jul 2007 Posts: 15 Location: Cordoba - Argentina
rs485.c problem
Posted: Thu Apr 09, 2009 1:45 pm
The thing is, there are not good examples coming with the compiler. I need also an example communicating 2 pics. I can't make it work with 2 max487, and 2 18F2553. With Proteus 7.4 and CCS 4.065.
When it wants to send something it doesn't put the DE line to high in the library so it's impossible to send something.
