Correct way to I/O
dcclark
Correct way to I/O
PostPosted: Wed Apr 08, 2009 5:44 am     Reply with quote
I wish to preserve the state of all but pins 0 - 2 of port J and then write a variable to those pins. I did the following:
Int8 b;
b = (input_j () & F8);
output_j (b | buffer[2]);
It works but, is it good programming Question
PostPosted: Wed Apr 08, 2009 6:44 am     Reply with quote
You should mask out the higher bits from buffer[2] to prevent corruption:
Int8 b;
output_j (b | (buffer[2] & 7));
Good luck
dcclark
PostPosted: Wed Apr 08, 2009 10:13 am     Reply with quote
Thanks Mr. Guest. That is one of those "Why didn't I think of that?" Smile
asmboy
and of course there is ......
PostPosted: Wed Apr 08, 2009 8:24 pm     Reply with quote
output_J( ( input_j()&F8) | ( buffer[2]&7));
dcclark
Re: and of course there is ......
PostPosted: Thu Apr 09, 2009 5:06 am     Reply with quote
Thanks. By now it should be perfectly obvious to the most casual observer that I am transitioning from BASIC to C.
Thanks again Asmboy, now that is elegant C code. Very Happy
dcclark
Re Correct I/O
PostPosted: Thu Apr 09, 2009 5:22 am     Reply with quote
And of course my CCS PCWHD compiler complained. The code should be thusly: output_j((input_j() & 0xF8) | (buffer[2] & 0x7));
Thanks again.
