Read Capture Registers
Frier001
PostPosted: Thu Apr 30, 2009 2:28 pm     Reply with quote
Is there any way to read the CCPR1 or ECCPR1 registers. I am using a 18F4680 and running 4.090.
Thanks in advance.
PostPosted: Thu Apr 30, 2009 2:34 pm     Reply with quote
Look in the CCP section of the 18F4680.h file. You will find pre-defined
#byte and #word identifiers for the CCP registers. You can put lines of
code in your program to directly access the CCP registers by using
these values. Here is the .h file location:
c:\program files\picc\devices\18f4680.h
