kender
[OT] My latest I2C bus – it’s time to brag |
Posted: Sun Apr 05, 2009 12:04 am |
Colleagues,
Thanks for the good tips on I2C bus that you have given me recently!
Now, I’d like to brag about the I2C bus in the project that I’ve just completed. It has the some interesting features:
* Four PICs: 1 master, 3 slaves. “simple” peripherals too: EEPROMs, I/O expander, pot.
* 2m cable. One of the slave PICs is at the end of the cable.
* The cable is hot-plugable.
* 300W @ 500kHz going through the same cable during I2C communication. High voltage in some modes of operation, high current in others. It’s EMI from the I2C’s perspective.
* Galvanic isolation of one of the branches.
Designing and bring it up was a lot of fun.
- Nick http://www.prolifictec.com
bsturm
Posted: Mon Apr 06, 2009 9:44 pm |
Congrats, it is a lot of work to get all that working reliably isn't it. I spent a solid week on my design with a master/slave board system. At first, it was not hot pluggable. By the end, it recovered nicely from cable unplugs and replugs. |
newpicer_ Guest
Posted: Tue Apr 07, 2009 7:03 pm |
you both using the hardware i2c module? |
bsturm
Posted: Tue Apr 07, 2009 7:55 pm |
I am using the hardware I2C... |
kender
Posted: Tue Apr 07, 2009 8:01 pm |
newpicer_ wrote: | you both using the hardware i2c module? |
My slave PICs use hardware I2C module (slaves pretty much have to use hardware I2C). In the beginning, the master was using the hardware I2C. Recently I wrote my own I2C bit-banging routines, because I needed to have timeout if the bus is stuck. _________________ Read the label, before opening a can of worms. |
bsturm
Posted: Tue Apr 07, 2009 8:20 pm |
I haven't had a problem with the bus getting stuck recently, but I do have the WDT enabled just in case. It is not the nicest way of getting unstuck, but it is better than nothing.
I may end up writing my own master too, but I hope to not have to. I have an excellent book on I2C from Square1 Electronics with great examples if I need to get further into it. |
