re programming in ccs picc compiler
ashrok88
PostPosted: Sat Apr 04, 2009 11:03 am     Reply with quote
hi all,
I tried doing the example program for bulk transfers in usb emulating rs232 for pic18f4550.
An array, with values that resemble a sine wave, was already assigned in that example program. I got that working.
Now I want to use the internal adc (an0, with sampling freq fosc/2) and store the sampled values instead of that array mentioned previously.
I initialized the adc setup in the main function and then called a function which is 'for 'looped to get 256 sample data and store it in an array.
#define SINE_TABLE_SIZE 256 ///global declarations
static int sine_table[SINE_TABLE_SIZE];
void arraysine(void){
int1 i;
int8 value;
for(i=0;i<256;i++){
set_adc_channel(0);
delay_us(10);
value = read_adc();
sine_table[i]=value;
I compiled it and loaded the hex into the pic but usb is not detected.
Any suggestions to make it work?
reply
thank you.
PostPosted: Sat Apr 04, 2009 11:40 am     Reply with quote
int1 i;
for(i=0;i<256;i++){
What is the maximum value that an 'int1' variable can hold ?
Also, what is the maximum size that an 'int8' variable can hold ?
ashrok
thank you for the reply
PostPosted: Sat Apr 04, 2009 1:03 pm     Reply with quote
oh.....
I realize the mistake now,
I changed it to int16 for both..
Is the code fine otherwise??
I get no errors on compiling..but
Is there anything I need to include for the device to be detected?
(I commented out the parameter settings inside main when we choose read options from project wizard and also the file inclusion part that contains my project path)
ashrok
PostPosted: Sat Apr 04, 2009 1:05 pm     Reply with quote
just for the code and the example code to be consistent Very Happy
PostPosted: Sun Apr 05, 2009 11:39 am     Reply with quote
hi
can any1 reply..
FvM
PostPosted: Sun Apr 05, 2009 11:44 am     Reply with quote
This ADC setting is legal for a maximum device clock of 2.8 MHz, which seems rather unlikely in USB operation. Did you notice the ADC acquisition time requirements in the datasheet?
ashrok88
hi
PostPosted: Sun Apr 05, 2009 12:10 pm     Reply with quote
yes the example uses bulk type of data transfer,,,
is it ok if i change the adc_setup to fosc/64 ?
in the example it transfers 512 bytes data..
regards
Ashrok
ashrok88
PostPosted: Sun Apr 05, 2009 12:15 pm     Reply with quote
or fosc_internal
