Problem with HS
Chevi
Problem with HS
PostPosted: Fri Apr 03, 2009 10:48 am     Reply with quote
#include <18F4620.h>
#device adc=10
#device icd=true
#fuses NOWDT, HS, NOMCLR, NOPROTECT, NOIESO, BROWNOUT, BORV21, NOPUT, NOCPD, NOSTVREN, DEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, NOLPT1OSC, CCP2B3
#use delay(clock=10000000)
void main (){
HS if clock is >4MHz. My clock is 10Mhz.
Error: "Could not start target. .... . Use view |valid fuses to find the correct clock fuse."
Best wishes
andreluizeng
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Fri Apr 03, 2009 11:17 am     Reply with quote
Try put HS in first......... =)
I think that the compilers set the fuses one by one in the order that you give to it. and in this issue, you are giving first the NOWDT... it is just a suggest.
regards.
Andre
PostPosted: Fri Apr 03, 2009 11:39 am     Reply with quote
What is your compiler version number? See the top of the *.lst file for this number.
PostPosted: Sat Apr 04, 2009 4:42 am     Reply with quote
CCS PCH C Compiler, Version 4.023, 25097 03-abr-09 18:39
Exclamation
PostPosted: Mon Apr 06, 2009 3:22 am     Reply with quote
Any suggestion?
PostPosted: Mon Apr 06, 2009 5:27 am     Reply with quote
Realistically, look at the thread to the top of the forum about V4 versions.
I'd not be at all surprised if a low 4.2x version, was not setting the fuses correctly. It is before the point, where V4, really began to work at all reliably....
