Keypad 4x3 and 16F877
Guest02
PostPosted: Mon Mar 30, 2009 12:27 pm     Reply with quote
I made one 4x3 keypad with standard switches like on PICDEM 2 board.
Hardware is made something like this
http://www.elektrotekno.com/userpix/6181_1_2.jpg
and i put 4x 10K resistors to row0,1,2,3.
If i use this code, when i press number 7,8,9 different LED on picdem lights up but there is no message on LCD. I don't know what's wrong.
The LED - B3 wont light up regardless what i click.
Because i don't get visual reply from picdem i don't know what is with other switches. Are they working or not?
#include <16F877.h>
#include "trans_LCD.c"
#include "trans_KEY.c"
void main() {
   char k;
   kbd_init();
   lcd_putc("\fReady...\n");
   while (TRUE) {
      k=kbd_getc();
      if(k!=0)
        if(k=='*')
          lcd_putc('\f');
          lcd_putc(k);
Guest02
PostPosted: Mon Mar 30, 2009 12:28 pm     Reply with quote
I use whole B port for this ... except B7
PostPosted: Mon Mar 30, 2009 12:44 pm     Reply with quote
Post where you got these drivers from.
The pull-up connections should look like this:
                +5 volts
                 | |  10K
                 | |  resistor
                 |_|
 To PIC pin ------o------ To Keypad row pin
Post a list of the connections between the PIC pins and the keypad
and the LCD.
Guest02
PostPosted: Wed Apr 01, 2009 11:48 pm     Reply with quote
drivers are from this forum.
Slightly modified LCDD.c & KBD.c
This is the schematics:
http://tinypic.com/view.php?pic=14voboh&s=5
PostPosted: Thu Apr 02, 2009 12:22 am     Reply with quote
Your schematic shows the resistors are connected to ground.
That's wrong. Those are "pull-down" resistors. I told you to
use Pull-Up resistors. My schematic shows a connection
to +5 volts. Change your circuit to connect the resistors to +5v.
John P
PostPosted: Thu Apr 02, 2009 6:48 am     Reply with quote
If you're using Port B, why fool around with resistors at all? Use the internal pullups, that's what Microchip put them there for.
