nina
menu and functions |
Posted: Tue Mar 31, 2009 6:32 am |
I have tried to do a menu with an lcd on this way:
When program goes to while loop (main program) this call the function menu and after read a key from a keyboard(4x3) go out from menu function and return to while loop (main program)
The problem it is not reading a key from keyboard..
The code I am trying do do is:
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,PUT,NOLVP,NOBROWNOUT
#include <ds1307.c>
#include <flex_lcd420.c>
#include <flex_kbd.c>
char menu(byte sec,int antigo,int status,char k){
kbd_init();
port_b_pullups(TRUE);
sec=read_ds1307(0);
if (antigo != sec){
lcd_gotoxy(1,1);
printf(lcd_putc,"%2X",sec);
lcd_gotoxy(1,2);
printf(lcd_putc,("1 - A"));
lcd_gotoxy(1,3);
printf(lcd_putc,("2 - B"));
lcd_gotoxy(1,4);
printf(lcd_putc,("3 - C"));
antigo = sec;
while (true){
k = kbd_getc();
return (k);
char k,sair;
byte hora,min,sec,dia,mes,ano;
int status = 1;
byte antigo = 0;
kbd_init();
lcd_init();
delay_ms(200);
init_ds1307();
sec=write_ds1307(0,0x00);
while (1)
menu(sec,antigo,status,k);
printf(lcd_putc,"ESCOLHEU OPCAO : %c",k); // to check if it is returning k
tks
nina |
andyfraser
Posted: Tue Mar 31, 2009 6:46 am |
How do you expect menu to return when you have the following :
Code: | while (true)
k = kbd_getc();
Also, why do you call kbd_init and port_b_pullups each time you call menu ?
Andy |
nina
lcd menu |
Posted: Tue Mar 31, 2009 8:39 am |
Thank you for your answer...It was a mistake call kbd_init and port_b_pullups ..
But how can I solve the problem to read the key inside the function menu??
tks again
nina |
andyfraser
lcd menu |
Posted: Tue Mar 31, 2009 1:10 pm |
Well you could do something like :
k = 0;
while ( ( k < '1' ) || ( k > '3' ) )
k = kbd_getc();
Andy |
nina
menu |
Posted: Wed Apr 01, 2009 4:23 am |
I have tried this but it is not return the value x.
What I want to do is return value x from de menu function to while loop inside the main function..
the code is
#include <16F877.h>
#include <ds1307.c>
char menu(){
char x;
lcd_gotoxy(1,2);
lcd_gotoxy(1,3);
lcd_gotoxy(1,4);
while (true){
x = kbd_getc();
if (x=='1'){
continue;
return (x);
char x;
kbd_init();
lcd_init();
delay_ms(200);
while (1)
menu();
printf(lcd_putc,"choice %c", x);
andyfraser
Menu |
Posted: Wed Apr 01, 2009 6:54 am |
First, please use the Code button when posting this much code.
Second, you need to assign x to the return value of Menu().
i.e.
x = menu();
printf(....
Andy |
