DS1820 help
rudy
View user's profile Send private message Send e-mail MSN Messenger
DS1820 help
PostPosted: Fri Apr 03, 2009 10:11 am     Reply with quote
Hi everyone.
I am using a single DS18B20 in my application, and it work fine, the problem is that suddenly, after reading the sensor, it shows wrong temperature, on the next reading cycle, it comes back to normal value.
I use lots of interruptions, Timer_0, Timer_1 and timer_2, and I am using CRC to check if the bytes are correct, driving me to suspicious that the DS1820 is not working properly.
Can anyone give me a help.
Regards;
Manoel.
PostPosted: Fri Apr 03, 2009 12:50 pm     Reply with quote
If you believe that interrupts are disrupting the timing in your DS18B20
driver, then disable/enable global interrupts around the critical sections
of the DS18B20 driver. If you do this, the DS18B20 may start to work
again, but you may have excessive delays in your interrupt servicing.
You will need to consider these issues.
rudy
PostPosted: Fri Apr 03, 2009 2:38 pm     Reply with quote
Never mind,
I found the problem on CRC check routine.
Instead of this:
if(shift_reg==crc_value)crc_test=1;
I wrote this:
if(shift_reg=crc_value)crc_test=1;
Thanks anyway.
Regards.
