gets() and getchar() |
Posted: Mon Nov 08, 2004 9:19 am |
I could use getchar() get individual ASCII data from RS232, but I could not use gets() function. what is the matter, I used this for testing
send 'RB' from rs232
used
char b; b1[30];
b=getchar()
if(b=='R')
output_high(PIN_a2);
and
gets(b1);
b=b1[0];
if(b=='R')
first code works, second didi not? |
Re: gets() and getchar() |
Posted: Mon Nov 08, 2004 9:29 am |
Anonymous wrote: | I could use getchar() get individual ASCII data from RS232, but I could not use gets() function. what is the matter, I used this for testing
used
char b; b1[30];
b=getchar()
if(b=='R')
and
gets(b1);
b=b1[0];
if(b=='R')
Gets, requires a line feed to terminate the string. Hence you would have to send 'RB', and then an <enter>, before the gets version will work.
Posted: Mon Nov 08, 2004 9:42 am |
Thank you Ttelmah, according to your suggestion, if I want to send several strings, like,
char a[10], b[10], c[10] from RS232
then
after send the a[10], I have to send a '\r' right? '\r\' is a return right?
and then afetr b[10] a '\r' afer c[10] a'\r' and then
I could use gets() like
char a1[10], b1[10],c1[10];
gets(a1);
gets(b1);
gets(c1);
to get the transfered data rght?
thank you. |
Posted: Mon Nov 08, 2004 9:49 am |
what I meaning in the last one is for multiple strings receives. |
krakatau
Posted: Wed Apr 01, 2009 2:38 am |
THANKS A LOT GUYS. i was required it.
thanksssssss
maybe thanks sent very years later. ![Wink](images/smiles/icon_wink.gif) |
