I got a question about PIC 16F877 set up analog to digital.
Brian
PostPosted: Fri Mar 27, 2009 4:06 pm     Reply with quote
Hello everyone,
I got a question about setup_adc_ports.
In the PIC 16F877, the port A and E are analog. I just need to set it up on PIN A0_A1_A2. and PIN E0_E1.
I used the command " setup_adc_ports(A0_A1_A2_ANALOG);"
and "setup_adc_ports(E0_E1_ANALOG);"
but it showed that "Undefined identifier A0_A1_A2_ANALOG"
and "Undefined identifier RE0_RE1_ANALOG"
I do not know what's wrong.
Any help will be appreciated.
Thank you very much.
Sincerely,
Brian
PostPosted: Fri Mar 27, 2009 4:15 pm     Reply with quote
Look in your 16F877.h file. It has the list of constants that may be used
with setup_adc_ports() function. Here is the file location:
c:\program files\picc\devices\16f877.h
Brian
PostPosted: Fri Mar 27, 2009 11:42 pm     Reply with quote
Hello PCM programmer,
I have already taken a look the pic16f877.h. I just need A0_A1_A2 and E0_E1 but it does not have this choice.
What is the mean "A0 A1 A5 E0 VRefh=A3 VRefl=A2"? I have no idea what reference means. What is the purpose?
Thank you so much.
Sincerely,
Brian
PostPosted: Fri Mar 27, 2009 11:52 pm     Reply with quote
I have already taken a look the pic16f877.h. I just need A0_A1_A2 and '
The choices given in 16F877.h are the only ones available.
To satisfy your requirements, you will have to upgrade to a 16F887.
This is a more advanced chip. It allows individual selection of Analog
or Digital mode on all analog pins.
Read the 16F877 data sheet, in the ADC section. External Vref is used
if you want reference voltages instead of the normal Vdd (+5v) and
ground. Normally you don't need to do this.
Brian
PostPosted: Sat Mar 28, 2009 12:06 am     Reply with quote
Thank you for your reply.
I understood now.
Thank you so much,
Sincerely,
Brian
PostPosted: Sat Mar 28, 2009 12:18 am     Reply with quote
If you are in the US or nearby, you can get the 16F887 (in DIP-40
package) for $2.64 + shipping from http://www.mouser.com
There is no minimum order. Part number: 579-PIC16F887-I/P
Or, possibly you can order a free sample from Microchip, but it might
not ship immediately.
