PIC18F8723 Analog to Digital Setup
PostPosted: Fri Mar 27, 2009 11:45 am     Reply with quote
CCS version 4.068
Hello!! I am trying to setup my A2D conversion on my pic but the voltage I read with a meter and the voltage I read with the pic are off by about 120mv. My chip uses a 12 bit A2D. here is my code.
This is the function I call:
void Get_Altitude()
int i;
atemp=0;
for(i=0;i<10;++i)
    set_adc_channel(1);
    delay_us(20);
    value=read_adc();
    avoltage=((value*(5.0367/(4095))));
    pressure=((avoltage)/(5.0367*.009)+.095/.009)*0.296133971;
    atemp=atemp+pressure;
atemp=atemp/10;
height=((1-pwr((pressure/29.785),.19026))*288.15)/.00198122;
  // printf("height %ld pressure %2.3f voltage %5.3f avgpressure %5.3f \r\n",height, pressure,avoltage, temp);
   //delay_ms(500);
Here is my setup in the main:
   //Basic Chip Setup
   setup_adc_ports(AN0_TO_AN1|VREF_VREF );
   setup_adc(ADC_CLOCK_DIV_8);
   setup_psp(PSP_DISABLED);
   //setup_spi2(SPI_MASTER|SPI_MODE_3|SPI_CLK_DIV_16);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(False);
   setup_oscillator(OSC_4MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
And:
#include <18F8723.h>
//#device ICD=TRUE
#device adc=12
#FUSES INTRC_IO                    //Internal Osc
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOPUT                    //No Power Up Timer
//#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES MCU                      //Microcontroller Mode
#FUSES NOWAIT                   //Wait selections unavailable for Table Reads or Table Writes
#FUSES BW16                     //16-bit external bus mode
#FUSES ABW16                    //16-bit Address bus
#FUSES ECCPE                    //Enhanced CCP PWM outpts multiplexed with RE6 thorugh RE3
I had everything working on a 4520 nicely but I needed more resolution. Thanks in advance.
PostPosted: Fri Mar 27, 2009 12:23 pm     Reply with quote
Get rid of the analysis code and display the raw ADC values every 500 ms.
Display them in hex (or decimal) and look for any problems.
See this recent discussion of Vref issues:
http://www.ccsinfo.com/forum/viewtopic.php?t=38276&highlight=vref
PostPosted: Fri Mar 27, 2009 12:45 pm     Reply with quote
My "Value" varies between 3418 and 3421. This along with the fact that that when I multiply that by 5/4095 I am still off 120mv which makes a huge difference for my application. But only varying a few steps I feel is pretty good. I don't know if there is a better way to setup the chip.
PostPosted: Fri Mar 27, 2009 12:57 pm     Reply with quote
See this section in the 18F8723 data sheet:
TABLE 2-1: TAD vs. DEVICE OPERATING FREQUENCIES
This clock divisor value is the correct one for your 4 MHz oscillator freq:
ADC_CLOCK_DIV_4
18F8723 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/18F8723%20Data%20Sheet_39894A.pdf
PostPosted: Fri Mar 27, 2009 1:28 pm     Reply with quote
Yeah I went through and tried setting that differently. It had no effect on my output at all. Can I go and just subtract the difference in the voltage, it would be like a manual offset?
