Bug EX_STR.C
volcane
Bug EX_STR.C
PostPosted: Sun Apr 12, 2009 2:46 pm     Reply with quote
Hi!
I'm using the development board CCS with 16f877A i uploaded example EX_STR.C
working normally, but when i pressed the enter key on the keyboard without releasing, the program on the PIC (EX_STR.C) is blocked.
PostPosted: Sun Apr 12, 2009 2:57 pm     Reply with quote
This example does not use #int_rda with a receive buffer, so it can only
receive characters when it's executing the get_string() function. If the
program is sending out text with a printf() statement and you send it
characters from the keyboard at the same time, the UART will lock up.
To fix the lock-up problem, add ERRORS to the #use rs232() statement
as shown below:
CCS should do this in most of their examples. For some reason, they
don't do it.
volcane
PostPosted: Sun Apr 12, 2009 3:22 pm     Reply with quote
Hi!
Working!!!
I wanted to add: the compiler shows a message Warning: variable never used: rs232_errors
PostPosted: Sun Apr 12, 2009 4:20 pm     Reply with quote
See this explanation by Ttelmah:
http://www.ccsinfo.com/forum/viewtopic.php?t=30917&highlight=rs232_errors&start=8
volcane
PostPosted: Sun Apr 12, 2009 4:44 pm     Reply with quote
Hi!
Thanks for the information, I believe that in the future I will use the ISR.
