16f84a interrupt program
guest_guess
PostPosted: Wed Mar 25, 2009 10:03 pm     Reply with quote
is there any example for interrupt prog for limit switch..
PostPosted: Thu Mar 26, 2009 12:49 am     Reply with quote
There is a program here that demonstrates some interrupt concepts:
http://www.ccsinfo.com/forum/viewtopic.php?t=17301&start=2
It's somewhat out of date, in that there is now a function called
clear_interrupt(). You don't need to write directly to the INTF_BIT
to clear it anymore. You can just call
clear_interrupt(INT_EXT);
