glcd+rtc
nina
glcd+rtc
PostPosted: Wed Mar 25, 2009 10:48 am     Reply with quote
When I simulate this code on Proteus, the variable secs count seconds but it doesn't erase the last value. I mean, it count 00 and 01 it is written over 00.
How can I solve this?
tks
nina
#include <16F877.h>
#include <glcd.c>
#include <ds1307.c>
byte hora,min,sec;
int status = 1;
char secs[8];
init_ds1307();
sec=write_ds1307(0,0x00);
glcd_init(ON);
glcd_fillScreen(OFF);
while(TRUE){
   sec=read_ds1307(0);
   sprintf(secs, "%X", (byte)sec); // Converts sec to text
   glcd_text57(1, 1, secs, 1, ON);
PostPosted: Wed Mar 25, 2009 3:19 pm     Reply with quote
Think about the problem. If a write-character routine is overlaying new
characters on top of existing characters, what can you do about it ?
Think. You would want to erase the old character before you write a
new one. How can you do that ? I can think of at least two ways.
What character could you write over the old one to erase it ?
What character would erase all other characters, if you write it on
top of an existing character ?
Or, what option does the glcd_text57() routine have (as a parameter),
to change the color of the character dots ? How can this option be
used to erase a previous character ?
nina
glcd+rtc
PostPosted: Wed Mar 25, 2009 6:59 pm     Reply with quote
PCM programmer..
thank you for your comments...I tried to do this, but now secs keep blinking...
#include <16F877.h>
#include <glcd.c>
#include <ds1307.c>
byte hora,min,sec;
int status = 1;
char secs[8];
init_ds1307();
glcd_init(ON);
while(TRUE){
   sec=read_ds1307(0);
   glcd_text57(15, 15, secs, 1, ON);
   glcd_text57(15, 15, secs, 1, OFF);
PICoHolic
PostPosted: Thu Mar 26, 2009 5:49 am     Reply with quote
try this:
#include <16F877.h>
#include <glcd.c>
#include <ds1307.c>
byte hora,min,sec;
int status = 1;
char secs[8] = {0};
init_ds1307();
glcd_init(ON);
while(TRUE){
   sec=read_ds1307(0);
   sprintf(secs, "%X\0", (byte)sec); // Converts sec to text
nina
PostPosted: Thu Mar 26, 2009 6:57 am     Reply with quote
PICoHolic...
I tried do this but the problem was time is not right because of delay.
That is the point...I thought do this way...
Do you have another way to solve this problem?
I want to display hour, min, sec
tks
nina
PICoHolic
PostPosted: Thu Mar 26, 2009 7:05 am     Reply with quote
The delay_ms(1000) is just for the display. The 1 second timing is coming from your DS1307 RTC.
I suggest that you feed the output of the DS1307 (1 sec clock) into one of your external interrupts and then update your display accordingly.
Good Luck
nina
glcd
PostPosted: Thu Mar 26, 2009 7:23 am     Reply with quote
but if i have a delay_ms(1000) inside a while loop and inside of this while loop I get reading from ds1307, so for sure I will have a delay between the real time( from ds1307) and the reading of ds1307.
tks again
nina
PICoHolic
PostPosted: Thu Mar 26, 2009 7:39 am     Reply with quote
Yes, but not that important...
Anyway if you insist on having it in a loop inside your main, try this out:
#include <16F877.h>
#include <glcd.c>
#include <ds1307.c>
byte hora,min,sec, old_sec = 0xFF;
int status = 1;
char secs[8] = {0};
init_ds1307();
glcd_init(ON);
while(TRUE){
   sec=read_ds1307(0);
   if (old_sec != sec) {
      old_sec = sec;
nina
gldc+rtc
PostPosted: Thu Mar 26, 2009 12:49 pm     Reply with quote
very nice...it is working..
Thanks you very much PICoHolic
Nina
