cfernandez
FAT Question |
Posted: Sun Mar 22, 2009 8:17 pm |
I want to use the FAT driver from CCS with a ATMEL dataflash, anybody make this?, Is possible?
Thank you very much! |
Posted: Mon Mar 23, 2009 12:15 am |
It should be usable (with some adaptions). Basically FAT can be used with any block addressable media. But you must observe this DataFlash requirement:
Quote: | To preserve data integrity, each page of a DataFlash sector must be updated/rewritten at least once within every 10,000 cumulative page erase/program operations. |
A simple algorithm is suggested in the datasheet, but it requires a non-volatile page pointer.
P.S.: I noticed, that newer DataFlash datasheets are using the term endurance, which has been apparently unknown at Atmel in the past. They specify 100k erase/write cycles at minimum. It's doubtful, if DataFlash should be used without a wear-leveling flash translation layer for FAT, that is permanently to some sectors (directory and FAT). |
