How to transmit to GSM module
syide
PostPosted: Sat Mar 21, 2009 4:41 am     Reply with quote
This response from my modem.
\0A21/2009 18:07:07.421 --> Latitude:AT+CMGF=1
OK
AT+CMGS="0129669558"
 > Latitude:0300.5810.N \0D
--> +CMS ERROR: invalid text mode parameter\0D
rs232(baud=4800,parity=N,xmit=PIN_C5,rcv=PIN_C4,bits=8,stream=GPS,errors)//data from GPS to PIC
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=GSM1,errors)// data from PIC to PC
#byte portc=7
char k;
char i;
char buffer[80];
char busca[]="GPGGA";
const int cr=0x0D; // PIC press ENTER
const int cz=0x1A; // PIC press Control-Z
set_tris_c(0x90);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
    do
         while ( fgetc(GPS) != 36 );
         for (k=0;k<17;k++)
         buffer[k]=fgetc(GPS);
      } while (strncmp(buffer,busca,5)!=0);
         {k=0;
            while (i!="*" && k<12)
              i = fgetc(GPS);
               buffer[k++]= i;
    fprintf (GSM1, "AT");
    fputc (cr, GSM1);                      // send ENTER (carriage return) signal
    delay_ms (2000);                       // wait half second
   fprintf (GSM1, "AT+CMGF=1");
   fputc (cr, GSM1);
   delay_ms (2000);
   fprintf (GSM1, "AT+CMGS=\"0129669558\"");
   fputc (cr, GSM1);
   delay_ms (2000);
   fprintf(GSM1,"\n\n\rLatitude:%s",buffer);
   fputc (cz,GSM1);
   delay_ms (2000);
   //fputc (cr,GSM1);
I want to tansmit data from gps to gsm.But i got error msg.It said "invalid text mode parameter".What the problem with the code? Question
PostPosted: Sat Mar 21, 2009 7:03 am     Reply with quote
There are at least two errors, that potentially can cause failure of the code:
- i is uninitialized in while (i!="*" && k<12)
- terminating \0 isn't missing in buffer
The latter may cause failure of the CMGS action by sending an unprintable character.
Also your said "response from modem" doesn't seem exact, where you got e.g. the "-->"? An exact hexdump of both directions would be better to understand, what's going wrong.
As a more general comment, your method of decoding NMEA-0183 seems rather dubious, it would be better to use field delimiters rather than fixed length. I don't see, that NMEA specifies a certain field length.
syide
PostPosted: Sat Mar 21, 2009 7:41 pm     Reply with quote
I am able to print
Latitude:0300.5810,N,
if i connect directly to hyperterminal without using modem.
Code.
#use rs232(baud=4800,parity=N,xmit=PIN_C5,rcv=PIN_C4,bits=8,stream=GPS,errors)//data from GPS to PIC
#byte portc=7
char k;
char i;
char buffer[80];
set_tris_c(0x90);
setup_adc(ADC_OFF);
setup_spi(FALSE);
    do
         while ( fgetc(GPS) != 36 );               // wait  $
         for (k=0;k<17;k++)
         buffer[k]=fgetc(GPS);   // store first 6 chars toel buffer[]  (GPGGA)
      } while (strncmp(buffer,busca,5)!=0);       // compare if the first five chars are GPGGA, if not, keep searching
         k=0, i=0;
              i = fgetc(GPS);
               buffer[k++]= i;
              buffer[k++] = '\0'; //terminate buffer
   fputc (cr, GSM1);
   delay_ms (2000);
   fputc (cr, GSM1);
   delay_ms (2000);
   fputc (cz,GSM1);
   delay_ms (2000);
   //fputc (cr,GSM1);
By the way "-->" didn't have in modem response.It is from hyperterminal.I dun know how to do hexdump.
Thank u
