I'm programming a 16f877a.h ... and I have in my program arrays ... at some point take values of other variables and I do not know why? Someone has this happened? please help
Posted: Mon Feb 25, 2013 1:14 pm
It is happening, because you are writing beyond the end of an array somewhere.
Arrays are not 'bounds checked' (the hardware does not support this). It is up to _you_ to be careful. So (for instance):
void some_code(void) {
int8 ctr;
for (ctr=1;ctr<=10;ctr++)
chars[ctr]=anumber;
//at this point 'something[0]' will probably have been overwritten
The problem here is that in C arrays are zero referenced. So chars has entries from 0 to 9. I then write to entries 1 to 10, and since (generally) variables are stored in memory in the order they are declared, chars[10], overwrites something[0].....
Common causes of problems are:
1) Forgetting arrays are zero referenced.
2) Forgetting strings need space for the terminating null.
3) Just general errors....
Posted: Mon Feb 25, 2013 1:17 pm
Read these threads. See if you are doing anything mentioned in them.
