Want to get the response from modem
syide
PostPosted: Wed Mar 11, 2009 1:18 pm     Reply with quote
Can everyone take a look to this code. I want to get the response from modem. Like when I send AT, the modem will return "ok". Then send it to hyperterminal.
#include <18F4620.h>
#include <string.h>
#fuses HS, NOWDT, NOLVP, NODEBUG, MCLR
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7,ERRORS,bits=8,stream=GPRS)
#use rs232(BAUD=9600,parity=N,XMIT=PIN_C5,ERRORS,bits=8,stream=PC)
#ifndef NULL
  #define NULL      0
const int cr=0x0D; // PIC press ENTER
  char buf[25];
  unsigned int8 i;
  setup_adc_ports(NO_ANALOGS);
  setup_adc(ADC_OFF);
  setup_spi(FALSE);
  setup_wdt(WDT_OFF);
  /***start test sequence***/
   while (true)
     delay_ms (1000);
     fprintf(PC,"\r\n***Program started***\n");
     delay_ms (1000);
     fprintf(GPRS,"AT");
     fputc (cr, GPRS);
     delay_ms (1000);
     for (i= 0; i <= 25; i++){
     buf[i] = fgetc(GPRS);                   //get the modem respond
     fprintf(PC,"%C",buf[i]);}
PostPosted: Wed Mar 11, 2009 3:34 pm     Reply with quote
First, if the modem starts to respond, before one second has passed, the response will at least in part, be lost.
Second, the code will then be stuck in the 'for' loop, till 26 characters are received. If less than this arrive, it'll sit here for ever...
syide
PostPosted: Wed Mar 11, 2009 10:40 pm     Reply with quote
How to solve this problem? is it by using kbhit()?
arunb
RE
PostPosted: Thu Mar 12, 2009 12:22 am     Reply with quote
Use the RDA interrupt, this captures whatever comes to the port, getc() will retrieve the data, you probably need to use an array instead of c.
#int_rda
void modem_cap()
  char c;
  c=getc();
syide
PostPosted: Sat Mar 14, 2009 1:35 am     Reply with quote
I still cannot get the response AT with this code.Question
Can someone show the way???
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
      // this blinks a LED :
      static int1 b;
      if (b)
      output_high (PIN_C0);
      output_low (PIN_C0);
      b = ! b;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
   char c;
   enable_interrupts(global);
   enable_interrupts(int_rda);
   fprintf(PC,"\r\n\Running...\r\n");
   fprintf(GPRS,"AT");
   fputc (cr, GPRS);
   delay_ms(2000);
   // The program will delay for 10 seconds and then display
   // any data that came in during the 10 second delay
   do {
      delay_ms(10000);
      while(bkbhit){
      c=bgetc();
      fputc(c,GPRS);
      fputc(c,PC);
   } while (TRUE);
