Atmel dataflash AT45DB321B driver for PIC18F452
Post new topic   Reply to topic    CCS Forum Index -> Code Library
dvsoft
PostPosted: Mon Aug 02, 2004 5:02 pm     Reply with quote
bonjour,
My DataFlash Drivers
//  Copyright (c) DVSoft 2004
//  email dvsoft@club-internet.fr
//  This program is free software; you can redistribute it and/or modify it
//  under the terms of the GNU General Public License as published by the
//  Free Software Foundation.
//  This program is distributed in the hope it will be useful, but WITHOUT
//  ANY WARRANTY; without even the implied warranty of MERCHANDIBILITY or
//  FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
//  more details.
//  Originale Unit Name : DTFDriver.c
//  Author              : Alain
//  Date                : 15-Avril-2004
//  Project             : YA1-LOGGER-V3
//  Version             : 0.9.0.1
//  Revision            :
//  DataFlash Driver AT45DB321B for CCS compiler
//  Inactive Clock Polarity High
//  level convertor 74F07 Hex inverter/buffer drivers (open-collector)
//  Pull-Up resistor 2K2
//  PIC18F452 TQFP        AT45DB321B
//    RC5 (SDO)      ->   DTF SI       (15)
//    RC4 (SDI)      <-   DTF SO       (16)
//    RC3 (SCK)      ->   DTF SCK      (14)
//    RE2 (/CS)      ->   DTF /CS      (13)
//    RE1 (WR)       <-   DTF RDY/BUSY (1)
//                        DTF /RESET    +3.3V
//                        DTF /WP       +3.3V
// Conditional PinDef
#ifndef __DTF_PIN_DEF__
    #define DTF_READY   PIN_E1
    #define DTF_CS      PIN_E2
// Conditional code for the dataflash state in eeprom
#ifndef __DTF_DATA_STORAGE__
    // ROM Space free
    #define PROGRAM_MEMORY_SIZE   getenv("PROGRAM_MEMORY")
    #define FLASH_ERASE_SIZE      getenv("FLASH_ERASE_SIZE")
    #define BUFFER_END            PROGRAM_MEMORY_SIZE-1
    #define BUFFER_START          (PROGRAM_MEMORY_SIZE-(FLASH_ERASE_SIZE*2))
    // Config ROM Space (Application not for DataFlash)
    #define CFG_BUFFER_START      BUFFER_START
    #define CFG_BUFFER_LEN        CFG_BUFFER_START+0x000E
    // DataFlash ROM Space
    #define DTF_BUFFER_START      (CFG_BUFFER_START+FLASH_ERASE_SIZE)
    #define DTF_BUFFER_LEN        (DTF_BUFFER_START+0x000E)
    // Rom Configuration
    #org CFG_BUFFER_START, CFG_BUFFER_LEN {}
    // DTPageCnt in ROM
    #org DTF_BUFFER_START, DTF_BUFFER_LEN {}
    // DataFlash PageCnt in ROM Space
    int16 DTFPageCntRomAddress;
// Dataflash Config
const int16 DTFBlockSize = 512;       // DTF block Size
const int16 DTFPageSize  = 528;       // DTF Page Size
const int16 DTFNbrPage   = 8192;      // DTF Nb Page
// Dataflash Macro
// see Dataflash AC Characteristics
// tCSS /CS Setup Time     250 ns
#define DTFSelect()\
        output_low(DTF_CS);\
        delay_cycles(3)               // 300 ns PIC18F452 at 40Mhz
#define DTFUnSelect()\
        output_high(DTF_CS);\
// DataFlash PIN 1 Ready/Busy
#define DTFIsReady()  (input(DTF_READY))
// DataFlash PageCount
int16   DTFPageCnt;
#byte   DTFPageCnt_L=DTFPageCnt
#byte   DTFPageCnt_H=DTFPageCnt+1
// DataFlash ByteCount
int16   DTFByteCnt;
#byte   DTFByteCnt_L=DTFByteCnt
#byte   DTFByteCnt_H=DTFByteCnt+1
// DataFlash Address
int16   DTFAddress;
#byte   DTFAddress_L=DTFAddress
#byte   DTFAddress_H=DTFAddress+1
// DataFlash Dump PageCnt
int16   DTFDumpPageCnt;
// DataFlash Full Flags
BOOLEAN DTFFull;
// DataFlash Buffer Select for Double Buffering
BOOLEAN DTF_Buffer_2_Active;
// DataFlash Driver State
BOOLEAN DTFDriverRun;
// Function : DTFReadStatus(void)
// Input    :
//      void
// return   :
//      int     The Status register value
// Modify   :
//      void
// Note     :
#separate
int8 DTFReadStatus(void)
    int8 Status;
    //--- Select
    DTFSelect();
    //--- Command Read Status
    spi_write(0x57);
    //--- Status Result
    Status = spi_read(0);
    //--- Unselect
    DTFUnSelect();
    return (Status);
// Function : DTFPageToRam(int16 PageNum)
// Input    :
//      int16 PageNum       Page index to load in memory buffer
// return   :
//      void
// Modify   :
//      Load the memory page 'PageNum' in current buffer (1 or 2)
// Note     :
//      Change the active buffer1 or Buffer2
#separate
void DTFPageToRam(int16 PageNum)
    //--- Active buffer to main memory page
    DTFAddress = (PageNum << 2);
    while (!DTFIsReady());
    //--- Select
    DTFSelect();
    //--- Buffer 2 is Active Buffer
    if (DTF_Buffer_2_Active) {
        //--- Memory Page To Buffer 1
        spi_write(0x53);
        //--- Set Buffer 1 Active
        DTF_Buffer_2_Active = FALSE;
    }// End IF
    //--- Buffer 1 is Active Buffer
    else {
        //--- Memory Page To Buffer 2
        spi_write(0x55);
        //--- Set Buffer 2 Active
        DTF_Buffer_2_Active = TRUE;
    }// End Else
    //--- 7 high address bits
    spi_write(DTFAddress_H);
    //--- 6 low address bits
    spi_write(DTFAddress_L);
    //--- don't care 8 bits
    spi_write(0x00);
    //--- Unselect
    DTFUnSelect();
// Function : DTFRAMToPage(int16 PageNum)
// Input    :
//      int16 PageNum       Page index to store
// return   :
//      void
// Modify   :
//      Store the current memory buffer in memory page 'PageNum'
// Note     :
#separate
void DTFRAMToPage(int16 PageNum)
    //--- Wait DTF_Ready
    //--- Select
    DTFSelect();
    //--- Use Buffer 2 ?
        //--- Buffer 2 To PAGE With Built In erase
        spi_write(0x86);
    }// End IF
    else {
        //--- Buffer 1 To PAGE With Built In erase
        spi_write(0x83);
    }// End ELse
    spi_write(0x00);
    //--- Unselect
    DTFUnSelect();
// Function : DTFInitDump(void)
// Input    :
//      void
// return   :
//      void
// Modify   :
//      Set the dataflash page dump 'DTFDumpPageCnt' to 0
//      Load the first memory page in memory buffer
// Note     :
#separate
void DTFInitDump(void)
    //--- First page to dump
    DTFDumpPageCnt = 0;
    //--- Load first page in memory buffer
    DTFPageToRam(DTFDumpPageCnt);
#separate
// Function : DTFDumpPacket(void)
// Input    :
//      void
// return   :
//      int     0   End off memory pages
//              1   Some memory pages left
// Modify   :
//     increment the dataflash page dump 'DTFDumpPageCnt'
// Note     :
//     Load in memory buffer the next memory page
int DTFDumpNextPage(void)
    //--- Next Page
    DTFDumpPageCnt++;
    //--- Not in Last Page ?
    if (DTFDumpPageCnt < DTFPageCnt) {
        //--- Load in memory buffer
        //--- OK
        return 1;
    }// End If
    //--- Fin
    return 0;
// Input    :
//      void
// return   :
//      void
// Modify   :
//      void
// Note     :
//     Dump the complet buffer to the serial UART
//     Send only the data in Dataflash buffer
#separate
void DTFDumpPacket(void)
    int8  TxBuffer;
    int16 ByteCnt;
    //--- Initialisation
    DTFSelect();
    //--- Buffer 2 is Active ?
        spi_write(0x56);
        spi_write(0x54);
    //--- 8 Dont'care Byte
    spi_write(0x00);
    //--- High Byte address
    spi_write(0x00);
    //--- Low Byte address
    spi_write(0x00);
    spi_write(0x00);
    //--- Byte Count
    ByteCnt = DTFPageSize;
    //--- Load In Buffer
    do {
        //--- Read One Byte
        TxBuffer = spi_read(0);
        //--- Put in serial UART
        putc(TxBuffer);
    } while (--ByteCnt);
    //--- Unselect
    DTFUnSelect();
// Function : DTFOpen(void)
// Input    :
//      void
// return   :
//      void
// Modify   :
//      Set the flag 'DTFDriverRun' to TRUE  if ok
//                                   FALSE if not Ok
//      Set the Flag 'DTFFull' to TRUE if (DTFPageCnt == DTFNbrPage)
//      Set the Byte Count 'DTFByteCnt' to 0
//      Set the Dump page counter 'DTFDumpPageCnt' to 0
// Note     :
#separate
void DTFOpen(void)
    int8 Status;
    //--- Setup du SPI
    setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_4|SPI_SAMPLE_AT_END);
    //--- Buffer 1 Is Active Buffer
    //--- DataFlash Storage Adresse
    DTFPageCntRomAddress = DTF_BUFFER_START;
    //--- DataFlashPageCnt
    DTFPageCnt = read_program_eeprom(DTFPageCntRomAddress);
    //--- Read the status register
    DTFReadStatus();
    //--- Read  2 just in case
    Status = DTFReadStatus();
    //--- Status OK ?
    //    AT45DB321B  (TABLE 4 and 5 page 8) Using Atmel's DataFlash document
    //     bit 7      bit6   bit5 bit4 bit3 bit2  bit1 bit0
    //    Rdy/Busy  Compare     Density code      reserved
    //       1         0      1    1    0    1     0    0
    if (Status & 0x80) {
        //--- i store the lastpage value in eeprom area
        // so you must provide this data
        DTFFull = (DTFPageCnt == DTFNbrPage);
        //--- First Word
        DTFByteCnt = 0;
        //--- Dump page Count
        DTFDumpPageCnt = 0;
        //--- DataFlash OK
        DTFDriverRun = TRUE;
    }// End If
        //--- DataFlash HS ?
        DTFDriverRun = FALSE;
// Function : DTFWriteToFlash(int8 Data)
// Input    :
//      int8 Data      Data to flash
// return   :
//      void
// Modify   :
//      Set the flag DTFFul if last page
// Note     :
//      Automatique store to memory area with built-in-erase when the ram buffer
// is full. Use double bufferring for fast operation
#separate
void DTFWriteToFlash(int8 Data)
    //--- Drivers RUN ?
    if (!DTFDriverRun)
        return;
    //--- DTF Full
    if (DTFFull)
        return;
    //--- Wait Ready
    //--- Start Write Ram
    DTFSelect();
    //--- Write To Buffer 1 ?
        spi_write(0x87);
    //--- Write to Buffer 2
        spi_write(0x84);
    //--- 8 Don't care Bit
    spi_write(0x00);
    spi_write(DTFByteCnt_H);
    spi_write(DTFByteCnt_L);
    //--- Write The Value
    spi_write(Data);
    //--- UnSelect
    DTFUnSelect();
    //--- Next Word Address In DataFlash
    DTFByteCnt++;
    //--- Last page Byte ?
    if (DTFByteCnt >= DTFPageSize) {
        //--- WriteRam Start Addresse
        DTFByteCnt = 0;
        //--- RAM To Memory page with builtin erase
        DTFRAMToPage(DTFPageCnt);
        //--- Next Page
        DTFPageCnt++;
        //--- Store the Last Page Value in PIC eeprom
        erase_program_eeprom(DTFPageCntRomAddress);
        write_program_eeprom(DTFPageCntRomAddress,DTFPageCnt);
        //--- Last Page ?
        if (DTFPageCnt >= DTFNbrPage)
            DTFFull = TRUE;
    }// End IF
alain
sumi
I really need help!!!
PostPosted: Sun Jul 27, 2008 10:22 pm     Reply with quote
Hi dvsoft. I'm sumi and i'm studying in polytechnic now. I'm supposed to write a program about AT45DB321D driver for PIC18f4520. I have found urs. But u r using CCS complier. I'm using MCC18 complier. So i'm trying to edit it but still a lot of problems. So plz can u help me to edit it for MCC 18 complier? I need it urgently for my major project. Thankz.... Smile
temopic
PostPosted: Sat Feb 14, 2009 6:44 pm     Reply with quote
Can I use this for at45db161d??
I am using also 18f4520
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
