Noobie Guest
PIC timer |
Posted: Wed Mar 11, 2009 2:41 pm |
I'm new in PIC programming and i've some question about PIC16F876A. Here are my Question: How long is the maximum delay can the PIC uC do? If I'd like to activate a sensor after 3 days (72Hrs) I turn ON the PIC, what should I use for such long delay?
Any examples can be referred?
Can someone help me on this matter? I need to solve this doubt for my Final Year Project.
Thank you. |
Posted: Wed Mar 11, 2009 3:13 pm |
If the only thing you want to do, after power-up of the PIC, is to wait
for 3 days, then you can just call delay_ms() in a loop.
This will give a one minute delay:
Then just create a for(;;) loop that calls it the required number of times.
A tip regarding the loop counter value:
Remember that in CCS, an 'int' is an unsigned 8-bit integer, and can take
values from 0 to 255. If you want a larger number, you need to use
declare it as 'int16' (0 to 65535) or 'int32'. |
necati
Posted: Wed Mar 11, 2009 3:21 pm |
Code: | #include <16f876a.h>
#fuses XT, NOPROTECT,PUT, NOWDT,BROWNOUT
#BYTE PORT_A=0X05
#BYTE PORT_B=0X06
#BYTE PORT_C=0X07
/***entegreterbiyecisi@yahoo.com***/
// LCD STUFF
#define LCD_RS PIN_b6
#define LCD_EN PIN_b5
#define LCD_D4 PIN_b4
#define LCD_D5 PIN_b3
#define LCD_D6 PIN_b2
#define LCD_D7 PIN_b1
#define FIRST_LINE 0x00
#define SECOND_LINE 0x40
#define CLEAR_DISP 0x01
#define CURS_ON 0x0e
#define CURS_OFF 0x0c
#use fast_io ( a )
#use fast_io ( b )
#use fast_io ( c )
/***entegreterbiyecisi@yahoo.com***///lcd
void LCD_Init ( void );
void LCD_SetPosition ( unsigned int cX );
void LCD_PutChar ( unsigned int cX );
void LCD_PutCmd ( unsigned int cX );
void LCD_PulseEnable ( void );
void LCD_SetData ( unsigned int cX );
int16 clock =400;
int8 hours=0,minutes=0,seconds=0;
int1 yz=0;
#int_TIMER1
void TIMER1() {
clock -=25 ;
if(clock <25 ) {seconds++;clock +=400;yz=1; //sec 1 artır 400
if(seconds == 60) {minutes++;seconds = 0; //60 puls ta min 1 artır
if(minutes == 60) {hours++;minutes = 0; //60 puls ta hour 1 artır
/*************************entegreterbiyecisi@yahoo.com******************************/
void main(void){
setup_adc_ports(no_analogs);
SET_TRIS_A (0b11111111);
SET_TRIS_B (0b10000001);
SET_TRIS_C (0b10000000);
setup_timer_1(t1_internal|t1_div_by_1);
enable_interrupts(int_timer1);
enable_interrupts(global);
PORT_A=0;
PORT_B=0;
PORT_C=0;
port_b_pullups(0b10000000);
lcd_init();
//LCD_PutCmd(CURS_ON);
LCD_PutCmd(CLEAR_DISP);
output_high (pin_c3);
delay_ms (100);
while(true){
if(yz==1){LCD_SetPosition (second_LINE+0);
printf(lcd_putchar,"\%02d:%02d:%02d",hours,minutes,seconds);
output_toggle(PIN_c2);
yz=0;}
if(hours==72){output_low (pin_c3);}
/***entegreterbiyecisi@yahoo.com***/ //lcd basla
void LCD_Init ( void ){
LCD_SetData ( 0x00 );
output_low ( LCD_RS );
LCD_SetData ( 0x03 );
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
LCD_SetData ( 0x02 );
LCD_PulseEnable();
LCD_PutCmd ( 0x2C );
LCD_PutCmd ( 0x0C );
LCD_PutCmd ( 0x01 );
LCD_PutCmd ( 0x06 );
LCD_SetData ( swap ( cX ) | 0x08 );
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) );
LCD_PulseEnable();
output_high ( LCD_RS );
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
output_high ( LCD_EN );
delay_us ( 100 );
output_low ( LCD_EN );
delay_ms ( 5 );
output_bit ( LCD_D4, cX & 0x01 );
output_bit ( LCD_D5, cX & 0x02 );
output_bit ( LCD_D6, cX & 0x04 );
output_bit ( LCD_D7, cX & 0x08 );
/***entegreterbiyecisi@yahoo.com***/ //lcd son |
Noobie Guest
Posted: Thu Mar 12, 2009 10:02 am |
Thanks for PCM programmer, i manage to have few minutes waiting, now i'm running the board and test for hrs and days experiment. thank you for info~ ^^
Thanks to necati for providing the code, however, i do not need to display my counter... But i'll consider to do it for my enhancement if i have extra time.. ^^ |
