delay_ms disables global interrupt
gs
PostPosted: Tue Mar 10, 2009 5:14 pm     Reply with quote
Hello, I have a simple test program that flashes a message on an lcd, and a timer1 interrupt that flashes a led. The message on the lcd is ok but the interrupt time does not work ok. The delay's used in the main program affect the timer1.
As I see from the .lst file, the compiler tests, and disables the global interrupts, when a delay_ms is compiled. Is there a way to avoid this?
In the CCS help file it says... If interrupts are enabled the time spent in an interrupt routine is not counted toward the time
I attach a part of the lst file.
....................    delay_ms(1000);
01EC:  MOVLW  04
01ED:  MOVWF  @@2C
01EE:  CLRF   29
01EF:  BTFSC  INTCON.GIE    <------------------
01F0:  BSF    29.7
01F1:  BCF    INTCON.GIE      <--------------------
01F2:  MOVLW  FA
01F3:  MOVWF  ??65535
01F4:  CALL   @delay_ms1
01F5:  BTFSC  29.7
01F6:  BSF    INTCON.GIE    <---------------------------
01F7:  DECFSZ @@2C,F
01F8:  GOTO   1EE
Is there something I do wrong?
I use version 4.084
the test program is this
#include <16F88.h>
#fuses   XT,NOWDT,NOPUT,noPROTECT,NOBROWNOUT,MCLR,NOLVP,NOCPD,INTRC_IO
#use   delay(clock=4000000)
#include <lcd420_keys_2.h>
int   ticks=5;
#int_timer1
void my_isr()
if(--ticks==0)
   output_high(pin_a2);
   delay_ms(10);
   output_low(pin_a2);
ticks=5;
delay_ms(200);      //just wait a bit
SETUP_TIMER_1(T1_INTERNAL|T1_DIV_BY_1);
enable_interrupts(INT_timer1);
do{
   lcd_putc("\f Hello !!!   ");
   lcd_putc("\f");
}while(1);
If I comment out the main's loop code as the following example, the interrupt works perfectly
do{
//   lcd_putc("\f Hello !!!   ");
//   delay_ms(1000);
//   lcd_putc("\f");
//   delay_ms(1000);
}while(1);
www.hlektronika.gr
PostPosted: Tue Mar 10, 2009 5:48 pm     Reply with quote
The quick and dirty way to fix it, is just to give every section of your
code it's own instance of the delay routines. I'm not suggesting this
is the best way to solve your problem or anything. It will eliminate
the problem of the compiler disabling interrupts for delays. See the
lines added in bold below:
#include <16F88.h>
int ticks=5;
#int_timer1
void my_isr()
if(--ticks==0)
delay_ms(10);
output_low(pin_a2);
ticks=5;
do{
lcd_putc("\f");
}while(1);
PostPosted: Wed Mar 11, 2009 3:16 am     Reply with quote
However, also worth doing a search here about this. Basically, putting delays inside the interrupt handler (except a few uSec, needed for timings to operate I/O lines etc.,), is generally uneccessary, and 'poor practice'. The compiler only disables interrupts in the external delays, _when delays are also used in the interrupt_.
For example, why not set your line high, and reprogram the interrupt to it triggers again in 10mSec, or program another interrupt to do this. Then get out of the ISR ASAP. This way your code can be getting on with other things, while waiting for the 10mSec....
gs
PostPosted: Wed Mar 11, 2009 5:14 am     Reply with quote
Thank you both for the replies.
It was not a good idea to use the delay inside the interrupt, but I needed to see if the interrupt is working. I could use output_toggle instead. The real interrupt does not have a delay in it , so everything works fine now.
I understand the reason of the problem. Everyday I learn something new in here.
Thanks a lot
www.hlektronika.gr
