Problem!! 74HC595 !!!
joerfrada
PostPosted: Mon May 11, 2009 12:58 pm     Reply with quote
I need the code 74HC595 with 4-Digits 7-Segments Display Cathode Common and DS1307 RTC (12-hour format AM/PM) on CCS C. Please help me. Crying or Very sad
asmboy
how to begin
PostPosted: Tue May 12, 2009 12:24 pm     Reply with quote
as a first step - you could show how you propose to connect the hardware in question and then have a go YOURSELF at writing some code - to at least show that YOU
(a) put in some effort to start with
and
(b) might actually have the chops to do what you inquire about.
as a rule, there are plenty of working professionals on the board who can and HAVE - had to deal with this EXACT sort of thing in the past.
i know i have dealt with SPI drive of the 595 and its higher powered
( TI.COM) TPICxxxx relatives.
And as kindly as i can state this:
I'm not here to do your work FOR you.
ECACE
PostPosted: Tue May 12, 2009 1:55 pm     Reply with quote
Take a look at:
\Program Files\PICC\Examples\EX_EXSIO.C
and
\Program Files\PICC\Examples\EX_DS1307.C
These should give you some information on it as well.
A HW Engineer 'trying' to do SW !!! Run!!!
PostPosted: Tue May 12, 2009 2:11 pm     Reply with quote
That file doesn't exist.
But there is a ds1307 driver in the Code Library:
http://www.ccsinfo.com/forum/viewtopic.php?t=23255
This example file has some 7-segment LED display code that uses
the 74595.c driver file. Look at the lcd_putd() function:
c:\program files\picc\examples\ex_zmd.c
ECACE
PostPosted: Tue May 12, 2009 2:42 pm     Reply with quote
Oops, my mistake. I had taken that driver and example code you are pointing to and saved the sample program as EX_DS1307.C.
