One of the Slave codes and the Master code
Olufola
PostPosted: Tue May 19, 2009 2:42 pm     Reply with quote
SLAVE CODE
#if defined(__PCM__)
#include <16F877.h>
#elif defined(__PCH__)
#include <18F4520.h>
#endif
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=194,force_hw)
BYTE address, buffer[0x10];
 BYTE incoming, state;
#INT_SSP
void  SSP_isr(void)
output_high(pin_d6);
clear_interrupt(int_SSP);
   state = i2c_isr_state();
   if(state < 0x80)                     //Master is sending data
      incoming = i2c_read();
      if(state == 1)                     //First received byte is address
         address = incoming;
      if(state == 2)                     //Second received byte is data
         buffer[address] = incoming;
   if(state == 0x80)                     //Master is requesting data
      i2c_write(79);
void main ()
   enable_interrupts(INT_SSP);
   while (TRUE)
   set_tris_c(225);
   output_high(pin_d4);
   delay_ms(120);
   output_low(pin_d4);
   delay_ms(120);
MASTER CODE
/#include <E:\My Files\My_custom_i2c_library.h>
#include <16F877.h>
#endif
#use i2c(MASTER, SDA=PIN_C4, SCL=PIN_C3,force_hw)
BOOLEAN slave_ready(BYTE );
void write_to_slave(BYTE, BYTE);
BYTE read_from_slave(BYTE);
void ssp_interrupt ();
byte address1 = 194;
byte address2 = 196;
byte address2 = 198;
byte address2 = 200;
byte address2 = 202;
byte address2 = 204;
byte address2 = 206;
byte address2 = 208;
byte address2 = 210;
byte address2 = 212;
byte data1 =0;
byte data2 =0;
byte data3 =0;
byte data4 =0;
byte data5 =0;
byte data6 =0;
byte data7 =0;
byte data8 =0;
byte data9 =0;
byte data10 =0;
VOID MAIn (void)
while (true)
data1 = read_from_slave(address1);
printf("data read from sensor 1 is %4u",(int32) data1);
delay_ms(120);
do
   while(!ext_eeprom_ready());
      i2c_start();
      state = i2c_write((0xa0|(BYTE)(address>>7))&0xfe);
      if(state == 0)
         state = i2c_write(address);
         if(state == 0)
            i2c_start();
            state = i2c_write((0xa0|(BYTE)(address>>7))|1);
            if(state == 0)
               data=i2c_read(0);
               i2c_stop();
               printf("data received is %4u", data);
      if(state == 1)
         i2c_stop();
   }while(state != 0);
BOOLEAN slave_ready(BYTE address)
   int ack;
   i2c_start();            // If the write command is acknowledged,
   ack = i2c_write(address);  // then the device is ready.
   i2c_stop();
   return !ack;
void write_to_slave(BYTE address, BYTE data)
   while(!slave_ready(address))
   i2c_start();
   i2c_write(address&0xfe);
   i2c_write(data);
   i2c_stop();
BYTE read_from_slave(BYTE address)
   BYTE data;
  // while(!slave_ready(address))
   i2c_start();
   i2c_write(address|1);
   data=i2c_read(0);
   i2c_stop();
   return(data);
   BYTE incoming, state,buffer[16],address;
         address = incoming;
      i2c_write(buffer[address]);
PostPosted: Tue May 19, 2009 2:55 pm     Reply with quote
Why did you start a new thread to post your code ?
You have an existing thread on i2c slave problems.
You should post the code in that thread.
PostPosted: Tue May 19, 2009 3:36 pm     Reply with quote
I will soon post the original versions of the code that did not work. That does not have any threading issues and yet did not work
PostPosted: Tue May 19, 2009 3:51 pm     Reply with quote
I don't mean 'thread' with regard to programming.
I mean 'thread' as a Topic posted on this forum.
You don't need 2 topics about i2c slaves.
Put all of your new i2c posts in the original topic, here:
http://www.ccsinfo.com/forum/viewtopic.php?t=38961
