| struct problem. |
Posted: Wed Mar 04, 2009 3:57 pm |
Hi
CCS: 4.083 / PIC:18xx2455
There are some problem in the asm, of this simple struct.
But the code compile and run, but the asm look real funny.
Can anybody explain what going on here?
(not production code just for testing!)
| Code: | void st() {
int16 t;
int8 c;
struct{
int16 v1;
int16 v2;
}x1[10];
c=1;
x1[c].v1=t;//why is this faster than the other?
x1[c].v2=t;//why is this so complicated?
x1[2].v1=t;//ok
x1[2].v2=t;//ok
| Code: | 0CB0: MOVLW 01
0CB2: MOVWF c
.................... x1[c].v1=t;
0CB4: MOVF c,W
0CB6: MULLW 04
0CB8: MOVF PRODL,W
0CBA: CLRF @@xAC
0CBC: MOVWF @@xAB
0CBE: MOVLW x1
0CC0: ADDWF @@xAB
0CC2: MOVWF FSR0L
0CC4: MOVLW x1>>8
0CC6: ADDWFC @@xAC,W
0CC8: MOVWF FSR0H
0CCA: MOVFF t+1,PREINC0
0CCE: MOVF POSTDEC0,F
0CD0: MOVFF t,INDF0
.................... x1[c].v2=t;
0CD4: MOVF c,W
0CD6: MULLW 04
0CD8: MOVF PRODL,W
0CDA: CLRF @@xAC
0CDC: MOVWF @@xAB
0CDE: MOVLW 02
0CE0: ADDWF @@xAB,W
0CE2: MOVWF @01
0CE4: MOVLW 00
0CE6: ADDWFC @@xAC,W
0CE8: MOVWF @03
0CEA: MOVF @01,W
0CEC: ADDLW x1
0CEE: MOVWF FSR0L
0CF0: MOVLW x1>>8
0CF2: ADDWFC @03,W
0CF4: MOVWF FSR0H
0CF6: MOVFF t+1,PREINC0
0CFA: MOVF POSTDEC0,F
0CFC: MOVFF t,INDF0
.................... x1[2].v1=t;
0D00: MOVFF t+1,x1+9
0D04: MOVFF t,x1+8
.................... x1[2].v2=t;
0D08: MOVFF t+1,x1+11
0D0C: MOVFF t,x1+10
0D10: GOTO 263E (RETURN)
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Wed Mar 04, 2009 10:15 pm |
The 'c' in x1[c] is a variable, and the compiler needs to generate code to calculate the address of x1[c].
Then the compiler needs to add to that address the offset of the struct items. For v1, it's at the start of the struct and presumably has a zero offset. That can be optimised away. v2 is not at the start of the struct, so extra code to add its offset is required.
When working with x1[2], the addresses can be calculated at compile time, and used directly in the code. _________________ Andrew |
Posted: Thu Mar 05, 2009 1:37 am |
Hi
If changing to another chip 16xx the code is real clean. I dont have the 4.084 but in the release list I can see that some 18xx problem is solved. |
Seoman Guest
Posted: Thu Mar 05, 2009 10:55 am |
I change some code, i would like to use a string inside the structure
| Code: | void st() {
int16 t;
int8 c;
struct{
int16 v1;
int16 v2;
char v3[10];
}x1[10];
c=1;
x1[2].v1=t;//ok
x1[2].v2=t;//ok
x1[2].v3="Hello"; //Error: Expecting LVALUE such as a variable name or *expression |
Seem that the compiler don't recognize v3 Why?
Posted: Thu Mar 05, 2009 10:59 am |
My Compiler is 4.065
sorry |
Nothing to do with the structure. You need to use strcpy, to copy strings. C can automatically move 'simple' types (numbers etc.), but strings are more complex, and can't be copied with a simple '='.
Wayne_
Posted: Thu Mar 05, 2009 11:00 am |
Try
sprintf(x1[2].v3, "Hello"); or
strcpy(x1[2].v3, "Hello");
You can only do a char array assignment at declaration of the var
char mystr[10] = "hello"; |
