UART PIC to PIC communication
red32terra
PostPosted: Thu Mar 05, 2009 4:29 am     Reply with quote
Hi, i want to communicate multiple PIC16F877a. One is sort of a master and the rest are slaves. I am using CCS version 4.084 with MPLAB ICD2 debugger. Sorry for the long code.
Here is the code of the master:
#if defined(__PCM__)
#include <16f877a.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#DEVICE *=16 //ICD=TRUE ADC=8
#use Delay (Clock=8000000)
#use i2c (SLAVE,sda=PIN_C4,scl=PIN_C3,address=0xa0,force_hw)
#use rs232(Baud=9600,Xmit=PIN_C6,Rcv=PIN_C7,parity=o)
#priority ssp, rda
enum {POLL,CTRL_ON,CTRL_OFF};
//int mode;
short int SOT_i2c=0,SOT=0,isPoll=0,isUpdate=0,isSendToAll=0,isBlink=0;
int maxOn[2], modemConf[5], priority[2][5];
int i2cBuff[17], packetType;
int ctr1,ctr2;
//byte msg;
unsigned char TXBuff[6], RCBuff[5];
unsigned int slaveAdd;
int ch;
int setCheckSum()
   long Tsum = 0;
   int TcheckSum = 0;
   for (ctr1=1;ctr1<4;ctr1++)
      Tsum = Tsum + TXBuff[ctr1];
   TcheckSum = make8(Tsum,0);
   return TcheckSum;
int getCheckSum()
   long Rsum = 0;
   int RcheckSum = 0;
   for (ctr1=0;ctr1<3;ctr1++)
      Rsum = Rsum + RCBuff[ctr1];
   RcheckSum = make8(Rsum,0);
   return RcheckSum;
void TXBuff_Init()
  for (ctr1=0;ctr1<5;ctr1++)
   TXBuff[ctr1] = 0;
  TXBuff[0] = 0x7E;
//Addressing
  if (slaveAdd == 2)
   TXBuff[1] = 0x22;
  else if (slaveAdd == 1)
   TXBuff[1] = 0x11;
  else if (slaveAdd == 3)
   TXBuff[1] = 0x33;
  else if (slaveAdd == 4)
   TXBuff[1] = 0x44;
  else if (slaveAdd == 5)
   TXBuff[1] = 0x55;
  TXBuff[2] = 0xA5; // Source address
 //PAcket Type for Master2
  if (packetType == POLL)
  TXBuff[3] = 0xFF;
  if (packetType == CTRL_ON)
  TXBuff[3] = 0xCA;
  if (packetType == CTRL_OFF)
  TXBuff[3] = 0xC3;
  TXBuff[4] = setCheckSum();
  TXBuff[5] = 0x04;
#INT_SSP
void ssp_interrupt()
if(i2c_poll())
ch = i2c_read(0); // read from i2c
      if (ch == 0xF1)
         isPoll = 1;
         packetType = POLL;
         slaveAdd = 1;
      else if (ch == 0xF2)
         isPoll = 1;
         packetType = POLL;
         slaveAdd = 2;
      else if (ch == 0xF3)
         isPoll = 1;
         packetType = POLL;
         slaveAdd = 3;
      else if (ch == 0xF4)
         isPoll = 1;
         packetType = POLL;
         slaveAdd = 4;
      else if (ch == 0xF5)
         isPoll = 1;
         packetType = POLL;
         slaveAdd = 5;
      else if (ch == 0x91)  //I2C Activate Control Setting
         isPoll = 1;
      else if (ch == 0x92)  //I2C ShutOff All Device
         isSendToAll= 1;
         packetType = CTRL_ON;
      else if (ch == 0x94)  //I2C Disable All Control
         isSendToAll= 1;
         packetType = CTRL_OFF;
      else if ((ch==0x41)&&(SOT_i2c==0))
         SOT_i2c = 1;
         ctr1=0;
      else if ((ch==0x04)&&(SOT_i2c==1))
      isUpdate = 1;
      SOT_i2c = 0;
         if (SOT_i2c==1)
         i2cBuff[ctr1]=ch;
         ctr1++;
#INT_RDA
void rcv_interrupt()
   int rcv;
    rcv = getc(); // read from i2c
   if ((rcv == 0x7E) && (SOT == 0))
      SOT = 1;
      isBlink = 1;
      ctr1 = 0;
      for(ctr2=0;ctr2<4;ctr2++)
      RCBuff[ctr2] = 0;
   else if ((rcv == 0x04) && (SOT == 1))
      SOT = 0;
      //if (RCBuff[3] == getCheckSum())
       if (RCBuff[0] == 0xA5) // Check if packet is for Slave 1
            if (RCBuff[2] == 0x5A) // Check if packet is POLL
          if (RCBuff[2] == 0x53) // Check if packet is CTRL ON
      //} // Checksum
      if (SOT == 1)
         RCBuff[ctr1] = rcv;
         ctr1++;
void main ()
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_SSP);
   set_tris_d(0x00);
   set_tris_c(0xFF);
   output_D(0x01);
   output_D(0x00);
   isPoll = 0;
   isBlink = 0;
   SOT_i2c = 0;
      if(isPOLL==1)
   //   output_high(PIN_D0);
      TXBuff_Init();
            for(ctr1=0;ctr1<=5;ctr1++)
            putc(TXBuff[ctr1]);
            delay_us(100);
   //   delay_ms(500);
   //   output_low(PIN_D0);
      isPoll=0;
      if(isBlink==1)
      output_low(PIN_D0);
      isBlink=0;
and here is the slave:
#use rs232 (baud = 9600, Xmit=PIN_C6, RCV=PIN_C7, parity=o)
#priority rda,
#BYTE ADCON0 = 0x1F
#BYTE ADCON1 = 0x9D
//int slaveAddress = 0x11;
enum {POLL,CTRL_ON,CTRL_OFF,STATUS,ACK};
short int SOT=0,isPOLL,off_flag;
int RCBuff[4],TXBuff[6];
int ctr1, ctr2;
unsigned int ACMonitor, packetType;
int setCheckSum()
   long sum = 0;
   int checkSum=0;
      sum = sum + TXBuff[ctr1];
   checkSum = make8(sum,0);
   return checkSum;
int getCheckSum()
   long sum = 0;
   int checkSum;
      sum = sum + RCBuff[ctr1];
   return checkSum;
void TXBuff_Init()
  TXBuff[0] = 0x7E;
//Addressing
  TXBuff[1] = 0xA5;
  TXBuff[2] = 0x33;
//PAcket Type for SLAVE
  if (packetType == STATUS)
      if (off_flag == 1)
    TXBuff[3] = 0x53;
    TXBuff[3] = 0x5A;
  else if (packetType == ACK)
     TXBuff[3] = 0x66;
   //TXBuff[4] = setCheckSum();
    TXBuff[4] = 0x04;
#INT_RDA
   int ch;
//   disable_interrupts(int_ad);
   if (kbhit())
    ch = getc(); // read from i2c
   if ((ch == 0x7E) && (SOT == 0))
      SOT = 1;
      ctr1 = 0;
      RCBuff[ctr2] = 0;
   else if ((ch == 0x04) && (SOT == 1))
      SOT = 0;
       if (RCBuff[0] == 0x33) // Check if packet is for Slave 3
            if (RCBuff[2] == 0xFF) // Check if packet is POLL
            isPOLL = 1;
          if (RCBuff[2] == 0xCA) // Check if packet is CTRL ON
            output_high(PIN_D1);
         if (RCBuff[2] == 0xC3) // Check if packet is CTRL_OFF
            output_low(PIN_D1);
      } // Checksum
      if (SOT == 1)
         RCBuff[ctr1] = ch;
         ctr1++;
void ADC_check()
 ACMonitor=read_adc();
// disable_interrupts(int_rda);
 if (ACMonitor > 0x6C)
  output_high(PIN_D7);
  off_flag = 0;
   output_low(PIN_D7);
   off_flag=1;
// enable_interrupts(int_rda);
void main ()
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_DIV_32);
//   enable_interrupts(INT_AD);  //enable interrupt on adc
   set_tris_d(0x00);
   output_d(0x81);
   output_d(0x00);
      ADC_check();
      if(isPOLL==1)
      packetType = STATUS;
       TXBuff_Init();
         putchar(TXBuff[ctr1]);
         delay_us(100);
      output_low(PIN_D0);
//      ACMonitor = read_adc();
      isPOLL = 0;
the problem is that Master PIC does not receive anything after Polling. The Slave responds to the POLL if the address is correct. Can you help me point out the problem. tnx for any help.
