A2D Conversion Not working
PostPosted: Mon Mar 02, 2009 11:13 am     Reply with quote
I cant get my analog to digital conversion working for PIC18F4520. Im watching "value" in MPLAB and it stays at zero. Sad
#include <18F4520.h>
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC                    //Internal RC Osc
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#include <float.h>
  #include <math.h>
  #include <stdio.h>
 int16 value;
   setup_adc_ports(AN0_TO_AN1|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_32 );
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_16);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(OSC_4MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
   While(1)
   set_adc_channel(0);
   delay_us(100);
   value=read_adc();
Im trying to read a variable pot attached to A0.
andreluizeng
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Mon Mar 02, 2009 11:39 am     Reply with quote
If you are not external supplying the ADC clock you need to configure the internal clock to work
try changing
by
and make sure that your pic is working, try blink some LED, because Im not comfortable with some used fuses like:
it sometimes can cause serious conflicts with another internal peripherals.
regards
André
Andre
PostPosted: Mon Mar 02, 2009 11:54 am     Reply with quote
Replaced origonal with setup_adc(ADC_CLOCK_INTERNAL); Tested blinking LED with success. Still "value is reading zero". Using the watch function in the view menu of MPLAB.
andreluizeng
PostPosted: Mon Mar 02, 2009 12:03 pm     Reply with quote
are you sure that read_adc makes the desired pin connected to the adc channel as input ??? if not... try setting up your port A pins as input (set_tris function)
regards
Andre
PostPosted: Mon Mar 02, 2009 12:04 pm     Reply with quote
Are you running this in the MPLAB simulator, or with an ICD2 debugger ?'
How are you testing this ? What board are you using ?
PostPosted: Mon Mar 02, 2009 12:24 pm     Reply with quote
I have a ICD3 and after reading what u said I outputted my "value" through rs232 to computer and I'm getting different numbers when I change the pot so for now i will assume its working . Also I am just using a standard breadboard for all my hookup including chip. I don't think I was using the "watch" feature in MPLAB correctly. Now that I'm getting values out I want to translate that into a voltage. Here my calcs:
10 bit ADC so resolution is (Vdd/2^10) to get voltage just multiply that by my value stored in value. Correct?
andreluizeng
PostPosted: Mon Mar 02, 2009 12:29 pm     Reply with quote
yes... it is correct.
regards.
Andre
PostPosted: Tue Mar 03, 2009 8:35 am     Reply with quote
Ok I found that I had a couple things incorrect when I was displaying the value. Here is my modified code:
 int16 value;
 float voltage;
   setup_wdt(WDT_OFF);
   setup_vref(FALSE);
   While(1)
   set_adc_channel(0);
   delay_us(100);
   value=read_adc();
   voltage=(value*.00494624);  //if i use value*(5/1023); it will display 0 on printout.
   //voltage=(value*(5/1023));  //if i use value*(5/1023);
   printf("total %lx voltage %lf \r\n",value, voltage);
Questions:
1. Why doesn't the second voltage calculations where i divide only display 0's?
2. Does anyone know where to find the information found in the printF statement such as %lx,%lf I search the forums to get them and I am wondering if there is a good place to find them. I check the maunual and didn't see them.
andreluizeng
PostPosted: Tue Mar 03, 2009 8:46 am     Reply with quote
you need to "tell" that you are treating with float numbers, or else you only will take 0'z
try
     voltage=(value*(5.0/1023));
or
     voltage=(value*( (float)5/ (float)1023));
regards.
Andre
