Timer roll over
Timer roll over
PostPosted: Tue Mar 03, 2009 8:41 am     Reply with quote
Hi
I use a linear rotary encoder to measure some length.
The encoder running on a belt. If the belt is moving the encoder is too.
The encoder is connected to Timer0, and inc++ on every rising edge.
If I read Timer0 and save it, then after some time I do it again.
Ex1:
oldtmp=get_timer0();
 //some time after…
 tmp=get_timer0();
oldtmp can now be 10 and tmp can be 50. easy part. Diff is 40.
But if oldtmp is 250, and tmp is 10 then I pass the roll over(timer overflow -> start from 0 again...).
 if (tmp<tmpold){
  res=(0x100-tmpold)+tmp;
 else {
  res=tmp-tmpold;
Is there a easy way to do that?
PostPosted: Tue Mar 03, 2009 10:06 am     Reply with quote
Your thinking too complicated. If res is an unsigned int8, it will always give a correct result, without special processing of overflows.
PostPosted: Tue Mar 03, 2009 10:36 am     Reply with quote
Hmmm..
Timer0 is used as 16 bit and res, tmp, tmpold is all 16 bit too.
My ex. is only 8bit because I think it's the same, if not please help me out.
When you say I think complicated what did you mean?
I'm little confused?
Fusillade
PostPosted: Tue Mar 03, 2009 10:38 am     Reply with quote
Correct, as long as you never expect that your result will be greater than 255. If you think your value ever may exceed 255, you might consider the following
- Create an int16 value (I called mine overflow).
- Generate an timer 0 overflow interrupt which will increment the int16 value by 0x100.
overflow = 0;
//some time after…
tmp=get_timer0();
res=tmp + (overflow-tmpold);
Note: This code does not take into account the fact that the overflow value may change between the time timer0 has been read a second time and the result is calculated. Additional code is necessary to check for those conditions depending on your application.
New:
Compiler Version: 5.078
IDE Version: MPLAB X V4.15
Devices: PIC18LF****
Old:
Compiler Version: 4.121
IDE Version: MPLAB IDE V8.63
Fusillade
PostPosted: Tue Mar 03, 2009 10:50 am     Reply with quote
Anonymous wrote:
Hmmm..
You were only making it complicated (meaning: unnecessary calculations) if you know for sure that you will sample timer 0 before timer 0 has had the opportunity to complete one full counter cycle.
His response still holds true for a 16-bit timer as well when using unsigned int16 values.
Ex:
oldtmp = 0xFF00
tmp = 0x0280
res = tmp - oldtmp
res = 0x0280 - 0xFF00
res = 0xFFFF0380
but since you are storing to an unsigned int16:
res = 0x0380
which is the correct answer so there is no need to check for overflow.
New:
Old:
PostPosted: Tue Mar 03, 2009 12:38 pm     Reply with quote
