Quick Signed Integer Question
Matthew Aurand
PostPosted: Mon Mar 02, 2009 11:55 am     Reply with quote
Hey guys,
I am trying to convert a signed int to an unsigned int. What is the format of a signed int? I can't find the info in the compiler manual...
I am using 32-bit ints.
The MSB I assume is the sign bit, so if I want to convert say '-1000' to '1000' all I need to do is clear the MSB?
Thanks!
-Matt
-Matthew A. Aurand
PostPosted: Mon Mar 02, 2009 12:01 pm     Reply with quote
They are stored in two's complement format:
http://en.wikipedia.org/wiki/Two's_complement
The quick way to get the Absolute value (to code it) is to use the ABS()
function.
Sydney
PostPosted: Mon Mar 02, 2009 2:00 pm     Reply with quote
You could do:
signed int32 value = -1000;
value = -value;
PostPosted: Mon Mar 02, 2009 2:04 pm     Reply with quote
With that method, he has to know ahead of time that the value is negative.
Or, he has to add a test (an if statement) to test if it's negative before
he does your code.
With the ABS() function, it works on either a positive or negative value.
You don't need to test it before you run the function on it.
