USB Task Issue
MicroManiac
View user's profile Send private message Send e-mail MSN Messenger
USB Task Issue
PostPosted: Mon Mar 02, 2009 5:57 am     Reply with quote
I was thinking of putting the USBTasks() inside a timer interrupt.
But i was wondering, if for some reason i am accepting data and the interrupt occurs, will this affect the data i am receiving?
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Albert Einstein
PostPosted: Mon Mar 02, 2009 6:34 am     Reply with quote
From what I saw when implementing the CCS C USB driver, USBTask() is surely not intended to be operated inside a timer interrupt function and most likely won't ever work in this mode. But you may want to try yourself.
Good luck!
