neal1 Guest
any comment? |
Posted: Thu Feb 26, 2009 7:51 am |
I just wrote some code for serial communication with my PIC16f628a.
I just need some comment on my code...please comments.
I compiled these code with MPLAB v8.10 and no error occur.
Any comments are welcome:P
code as below:
Code: | #include <ctype.h>
#include <16f628a.h>
#FUSES NOWDT, HS, NOPUT, NOPROTECT, BROWNOUT, MCLR, NOLVP, NOCPD
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8)
//#byte CMCON =0x1f
#byte CMCON = 0x1f
#byte portb = 0x06
#byte porta = 0x05
#byte RCSTA = 0x18
#byte Txreg = 0x19
#byte Rxreg = 0x1A
#bit RCIF = 0x0c.5 // PIR1 register,Flag bit RCIF will be set when reception is complete
#bit TXIE = 0x8c.4 //PIE register Flag bit TXIE is zero for Disables the USART transmit interrupt
#byte TXSTA = 0x98
#bit BRGH = TXSTA.2
#bit SYNC = TXSTA.4
#bit TXEN = TXSTA.5
#bit TX9 = TXSTA.6
#byte RCSTA= 0x18
#bit RX9 = RCSTA.6
#bit SPEN = RCSTA.7
#bit CREN = RCSTA.4
#byte SPBRG=0x99
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(False);
// TODO: USER CODE!!
output_low(portb);
output_low(porta);
CMCON =0x07; //enable pins for I/O function
SET_TRIS_A(0x00); //TRISA<5> always read as 1
SET_TRIS_b(0x02); //TRISB<1> bit needs to be set and TRISB<2> bit cleared in order to configure pins RB2/TX/CK and RB1/RX/DT as the Universal Synchronous Asynchronous Receiver Transmitter pins.
SPBRG=0x81; //129 decimal, using ASYNCHRONOUS MODE (BRGH = 1)
output_low(SYNC); //Asynchronous mode
output_high(TXEN); //Enable transmission
output_low(TX9); //enable 8bit transmittion
output_high(BRGH); //Asynchronous mode high speed
output_high(SPEN); //enable serial port receive
output_low(RX9); //enable 8 bit reception
output_high(CREN); //Enables continuous receive
output_low(portb);
output_low(porta);
while(1){
printf("srsrsrsr\n");
if (RCIF==1){
porta ='A';
}//end if
}//end while
}//end main |
Posted: Thu Feb 26, 2009 12:36 pm |
Comments:
1. Don't do direct register access. You don't need to do it.
Invoke the CCS library code with a #use statement, and
use CCS functions.
2. Before using CCS functions, read the manual on each function
and see how to properly use it.
3. Don't just "throw" code together. Understand every line, and
use the proper parameters for a function. In embedded
programming, everything is important. |
FvM
Posted: Thu Feb 26, 2009 1:20 pm |
Furthermore, if accessing SFR directly for some reason, do it according to the CCS C documentation. output_low() and output_high() are creating special code for IO ports, including direction register setup. They aren't intended for any other SFRs and most likely cause unexpected behaviour. They surely don't work with a byte address, as in your code. |
neal1 Guest
Posted: Fri Feb 27, 2009 6:19 am |
How about writing like this way? I simulate with MPSIM and seem work fine...
#include <ctype.h>
#use fast_io(a)
#use fast_io(b)
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,ENABLE=PIN_B4)
int i;
setup_vref(FALSE);
output_a(0x00);
output_b(0x00);
i=getc();
while(1){
printf("welcome\n");
printf("press 1 to Turn On LED1\n" );
printf("press 2 to Turn On LED2\n" );
switch(i){
case'1':
printf("LED1 Turned ON");
case'2':
printf("LED2 Turned ON");
/*if (kbhit())//wait until a character has been received
printf("hello!!\n");
else if (PIN_B3==1)
printf("hi!!\n");*/
}//end while
}//end main | BUT I NOT SURE CAN SWITCH THE 'i' CORRECTLY? |
Posted: Sun Mar 01, 2009 1:38 pm |
Code: | #use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,ENABLE=PIN_B4)
| Do you really require the ENABLE keyword? This is normally only used for switching the external bus drivers to a tri-state mode. Not a common thing to do in RS232, unless you are using another driver like RS485 of course. Skipping the enable function will free a hardware pin for other usage.
An improvement would be to add the ERRORS keyword. Without this keyword the hardware UART will freeze on a receive buffer overflow (3 characters).
Move this line inside the loop. For example, just before the switch statement. |
