K.I.S.S. / SMACK Protocol
zagoaristides
View user's profile Send private message Visit poster's website ICQ Number
PostPosted: Sun Aug 31, 2008 6:35 pm     Reply with quote
Hello, I'm trying to make any of these protocols work in a pic. I need to make a token ring connection so every PIC connects to a master who receives data at high speed via RS232 (I use the port not the protocol). If anyone has something related to this please contact me so we can speed up things. Thanks a lot.
It goes like this:
http://www.ka9q.net/papers/kiss.html
http://www.symek.com/g/smack.html
And something helpful about the messages
http://www.javagroups.com/javagroupsnew/docs/javadoc/org/jgroups/protocols/SMACK.html
gip_mad
PostPosted: Wed Sep 03, 2008 8:46 am     Reply with quote
I don't know these protocols, but did you consider using a CAN bus? Very affordable, already integrated in some PICs, safe, collison detection....
zagoaristides
Reply
PostPosted: Sun Sep 14, 2008 5:32 pm     Reply with quote
gip_mad wrote:
I don't know these protocols, but did you consider using a CAN bus? Very affordable, already integrated in some PICs, safe, collision detection....
The thing goes like this, maybe you can help me. I want to send the data from a sensor device with 3 accelerometers (3 axis) via X(any) protocol to a master pic, but this master has to check how many devices (Maxim of 3) are connected to it. Well I thought about a token ring with this protocol because I can put a head data in the transmission so then the repetition is increased by one in each device, so when the full stream of data arrives to the master, it can check how many devices connected to that port it has. But I'm stuck.
gip_mad
PostPosted: Mon Sep 15, 2008 12:24 am     Reply with quote
For this low device count, I think you're better use simple analog input to every sensor... But for the bus thing, well, CAN can do the trick! You can send a "broadcast" message, and every sensor replies without collision so you know who is connected. Adding a sensor is as simple as plug-in... As long as you put different addresses on every device. You can also negotiate addresses at power up as I did in my application.
Can can also be very fast, so it can be used in real time applications (it is designed for automotive communications).
zagoaristides
PostPosted: Tue Feb 24, 2009 10:33 am     Reply with quote
Do you have an example of the use and some text to read?
