Is this the way to make connection between Modem<=>18f
syide
PostPosted: Mon Feb 23, 2009 12:57 am     Reply with quote
Anyone please tell me whether this code will work.
I try to connect Siemen Hc25 terminal with PIC.
PIC work as client to send data to server in PC.
Siemen HC25 did have TCP/IP stack AT cammand. Here is the code
#include <18F4620.h>
#fuses H4, NOFCMEN, NOXINST, NOIESO, NOPBADEN, MCLR, NOWDT, NOPROTECT, NODEBUG, NOSTVREN
#define STACK_USE_PPP   1
#define STACK_USE_MAC   0
#define STACK_USE_ICMP  1     //for ping
#define STACK_USE_TCP   1     //To send TCP packets (talk to HTTP clients)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7, STREAM=USER)
#include "tcpip/stacktsk.c"    //include Microchip's TCP/IP stack
#define MY_HTTP_SOCKET  80
int8 HTTPSocket=INVALID_SOCKET;
void HTTPPut(char c) {
   TCPPut(HTTPSocket, c);
void HTTPTask(void) {
   static enum {HTTP_ST_CONNECT=0, HTTP_ST_WAIT_CONNECT=1, HTTP_ST_GET=2,
      HTTP_ST_PUT=3, HTTP_ST_DISCONNECT=4, HTTP_ST_FORCE_DISCONNECT=5} state=0;
   static TICKTYPE timeout_counter;
   TICKTYPE current;
   static char lc, lc2;
   char c;
   char content[250];
   int8 a0, a1;
   current=TickGet();
   if (!MACIsLinked()) {
      if (HTTPSocket!=INVALID_SOCKET) {
         state=HTTP_ST_FORCE_DISCONNECT;
   if (HTTPSocket==INVALID_SOCKET)
      state=HTTP_ST_CONNECT;
   switch(state) {
      case HTTP_ST_CONNECT:
         if (MACIsLinked()) {
            HTTPSocket=TCPListen(MY_HTTP_SOCKET);
               state=HTTP_ST_WAIT_CONNECT;
      case HTTP_ST_WAIT_CONNECT:
         if (TCPIsConnected(HTTPSocket)) {
            state=HTTP_ST_GET;
            timeout_counter=current;
      case HTTP_ST_GET:
         if (!TCPIsConnected(HTTPSocket)) {
         if (TCPIsGetReady(HTTPSocket)) {
            while (TCPGet(HTTPSocket, &c)) {
               if ( (c=='\n') && (lc2=='\n') ) {
                  state=HTTP_ST_PUT;
                  TCPDiscard(HTTPSocket);
               lc2=lc;
               lc=c;
         else if (TickGetDiff(current, timeout_counter) > ((int16)30 * TICKS_PER_SECOND))
            state=HTTP_ST_DISCONNECT;
      case HTTP_ST_PUT:
         if (TCPIsPutReady(HTTPSocket)) {
            a0=read_adc();
            set_adc_channel(1);
            delay_us(20);
            a1=read_adc();
            set_adc_channel(0);
            sprintf(content, "<HTML><BODY><H1>HELLO</H1><P>AN0 = 0x%X<BR>AN1 = 0x%X</BODY></HTML>", a0, a1);
            printf(HTTPPut, "HTTP/1.1 200 OK\r\n");
            printf(HTTPPut, "Content-Type: text/html\r\n");
            printf(HTTPPut, "Content-Length: %u\r\n",strlen(content));
            printf(HTTPPut, "\r\n");
            printf(HTTPPut, "%s", content);
            TCPFlush(HTTPSocket);
            state=HTTP_ST_GET;
      case HTTP_ST_DISCONNECT:
      case HTTP_ST_FORCE_DISCONNECT:
         TCPDisconnect(HTTPSocket);
char ppp_username[32];
char ppp_password[32];
char ppp_phonenumber[20];
void ISPInit(void) {
   sprintf(ppp_username, "     ");
   sprintf(ppp_password, "     ");
   sprintf(ppp_phonenumber, "*99***1#");
void main(void) {
   MODEM_RESP resp;
   ISPInit();
   //setup_adc_ports(ANALOG_AN0_TO_AN1);
   //set_tris_a(3);    //set A0 and A1 to input for ADC
   //set_tris_b(0);
   //setup_adc(ADC_CLOCK_INTERNAL);
   StackInit();
   while(TRUE) {
      if (!ppp_is_connected() && !ppp_is_connecting()) {
         printf("\fDialing");
         resp=ppp_connect(ppp_username, ppp_password, ppp_phonenumber);
         if (resp==MODEM_BUSY) {
            printf("\fBusy Signal");
            delay_ms(2000);
         else if (resp==MODEM_NO_DIALTONE) {
            printf("\fNo Dialtone");
            delay_ms(2000);
         else if (resp!=MODEM_CONNECTED) {
            printf("\fDial Error");
            delay_ms(2000);
         else {
            printf("\f%LUbps", connected_baudrate);
            printf("\nNegotiating PPP");
      StackTask();
      HTTPTask();
PostPosted: Mon Feb 23, 2009 1:52 pm     Reply with quote
I didn't look closely at your program, but there is one immediate error.
You're using the H4 fuse, but your clock speed is set to 4 MHz.
The H4 fuse multiplies the crystal frequency by 4. So if you have a
10 MHz crystal, you get 40 MHz oscillator speed. If you really have a 4
MHz crystal, then change the fuse to XT instead of H4.
a0=read_adc();
set_adc_channel(1);
delay_us(20);
a1=read_adc();
set_adc_channel(0);
You should set the channel before you read the adc. Not after.
This is the correct order for the lines of code:
set_adc_channel(0);
delay_us(20);
result = read_adc();
