Send A Number Of Characters To LCD
gazzanet
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Feb 19, 2009 4:49 am     Reply with quote
Hello, I'm using a LCD with built in ASCI compatible driver.
My code as it stands send 1 character per line, I want to be able to type all the characters together on one line.
After the LCD setup the program enables the register select bit.
I then use...... DATA('H'); //this sends a h to the lcd
if i then send DATA('I'); //this sends I to lcd
By sending the register select back to low the lcd displays HI
I can't seem to get a string working correctly what i have tried is....
void writestring(const rom char *s)
     unsigned char c;
     while((c=*s++)!='\0')
      DATA(c);
The error i get is in the declaration of the string.
void writestring(const rom char *s);
the error it gives is expected a , or )
Thanks in advance
PostPosted: Thu Feb 19, 2009 3:39 pm     Reply with quote
See this post for an example of how to declare 'const' strings, and then
pass a pointer to them, to another function:
http://www.ccsinfo.com/forum/viewtopic.php?t=34682&start=4
gazzanet
PostPosted: Fri Feb 20, 2009 4:26 am     Reply with quote
Yes i found the same thing in the ccs manual in the end after a very long looking time.
Is this the explanation of the answer you gave ?......
A (non-standard) feature has been added to the compiler to help get around the problems created
by the fact that pointers cannot be created to constant strings. A function that has one CHAR
parameter will accept a constant string where it is called. The compiler will generate a loop that will
call the function once for each character in the string.
Also. many thanks for your reply Razz
