pic 16F88 usart issue
PICJoey
PostPosted: Thu Feb 19, 2009 7:08 pm     Reply with quote
I am workin on PIC16f88 USART and not able to get it to work. I actually downloaded a code from a forum and programmed the microcontroller with it, but it doesnt work.
The code has to transmit the word "test" to the hyperterminal at 9600Mbps, I cannot see any thing in the hyperterminal. I am using a external 4MHz oscillator.
Every thing in the code seems to b fine, all the registers set properly. I dont know whats goin on wrong Sad . Please let me know if some thing is wrong with the code.
include p16f88.inc
        org      0x000
count equ 0x20
main   ; bcf   STATUS,RP0
       ; bcf      STATUS,RP1
        clrf     PORTA
        clrf     PORTB
        ; RB2 - Incoming Data RX
        ; RB5 - Outgoing Data TX
        movlw    B'11011111'
        bsf      STATUS,RP0
        movwf    TRISB
        ; 4MHz for 9600 baud rate
        ; See http://www.picbasic.co.uk/forum/showthread.php?t=214
        movlw    0x19
        movwf    SPBRG
        ; 8-bit asych mode, high speed uart enabled
        movlw    0x24   ; BRGH=1  20 BRGH=0
        movwf    TXSTA
        ; Serial port enable, 8-bit asych continous receive mode
        movlw    0x90
        bcf      STATUS,RP0
        movwf    RCSTA
loop1   movlw   0x45   ;'t'
        call    putc
        call    delay
        movlw   0x65   ;'e'
        call    putc
        call delay
        movlw   0x47   ;'s'
        call    putc
        goto delay
        movlw   0x45   ;'t'
        call    putc
        call delay
        movlw   0x0D   ; CR
        call    putc
        call  delay
        movlw   0x0A   ; LF
        call    putc
        ; remove next line and program will echo input from PC
        goto    loop1
loop2   nop
        getc   btfss   PIR1,RCIF
        goto   getc
        movf    RCREG,W
        call    putc
        goto    loop2
putc    btfss   PIR1, TXIF
        goto   putc
        movwf   TXREG
       movlw   0xf
       movwf   count
        return
delay
    nop
    nop
    nop
    nop
   decfsz count
   goto  delay
   return
   end
PostPosted: Thu Feb 19, 2009 7:24 pm     Reply with quote
PostPosted: Thu Feb 19, 2009 7:26 pm     Reply with quote
Do you have the CCS compiler ? This is not a Microchip MPASM forum.
If you do, here's a test program:
#include <16F88.H>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_B5, rcv=PIN_B2, ERRORS)
int8 c;
   c = getc();   // Get char from PC
   putc(c);  // Send it back to the PC
If you're using MPASM (with MPLAB), then you should ask your questions
in the Microchip UART forum:
http://forum.microchip.com/tt.aspx?forumid=12
