I am trying to connect my PIC18F4550 (and 18F85j50) to my PC which has Linux installed.
I need the right driver! Can anyone help me?
Now when I attached my PIC to usb port, it saw an ACM device, and I use puuty on port ttyACM0 to send data ( it works not very well ), but I can't receive data.
Bye
muisca
try an redirected echo
Posted: Tue Feb 24, 2009 5:03 pm
Hi I'm able to receive string from CDC device on linux using a pipe to another terminal, something like:
[linux@user] cat /dev/ttyACM0
if not sure wich terminal you should use, you can always count with dmesg command wich will tell you what kind of device and how the O.S mapped it.
