damis
| I2C send several data |
Posted: Sun Feb 22, 2009 6:34 pm |
Hi everybody, i'm just starting in embedded system.
I have a little problem, i try send one data , and it's size is a int16 bit,
but this code work when i send one data of int8 bit.
Please help me : that my code.
| Code: | ////// Master///////
#include <16F883.h>
#device ADC=10
#fuses INTRC,NOWDT,MCLR,DEBUG,NOPROTECT,NOLVP,NOBROWNOUT,NOPUT,NOCPD
#use delay(clock=8000000) // (8000000)8MHz Clock ,31kHz
#use i2c(MULTI_MASTER, sda=PIN_C4,scl=PIN_C3,force_hw )//
//#use i2c(MULTI_MASTER, sda=PIN_C4,scl=PIN_C3, force_hw)
#define LED PIN_B4
#define t 0x08
#define end_1 0xA0 //adresse de l'esclave
int8 val,val1,val2,val3;
//fonction d'envoie de donnée à l'esclave
void envoie_i2c(BYTE end_disp, BYTE adr, int8 data )
i2c_start(); //commence la transmission
i2c_write(end_disp); //choisie l'addresse de l'esclave avec qui communiqué
i2c_write(adr); //envoie l'adresse de la donnée
i2c_write(data); //envoie la donnée
i2c_stop(); //arrêt de la communication
delay_ms(100); //delay
// set_tris_b(0xFF);
set_tris_c(0b10111111);
setup_oscillator(OSC_1MHZ,0); //(8MHZ,31kHZ)set oscillator to 8Mhz
val = 200;
val1 = 155;
val2 = 230;
val3 = 45;
val = 0x1211;
val1 = 0x3421;
val2 = 0x4312;
val3 = 0x2143;
output_high(LED);
delay_ms( 500);
output_low(LED);
envoie_i2c(end_1, t,val ); //envoie une donnée a l'esclave
output_high(LED);
envoie_i2c(end_1, t,val1 ); //envoie une donnée a l'esclave
output_low(LED);
envoie_i2c(end_1, t,val2 ); //envoie une donnée a l'esclave
output_high(LED);
envoie_i2c(end_1, t,val3 ); //envoie une donnée a l'esclave
output_low(LED);
| Code: | ////////////////////////////////////
/////SLAVE//////////////////////////
#include <16F877.h>
#device adc=10
#FUSES XT //
#use i2c(SLAVE,sda=PIN_C4,scl=PIN_C3,address=0xA0, force_hw)
#include "C:\mplab_projet\flex_lcd_aba.c"
#define LED PIN_B3
int state, address, buffer[0x08]; // address and array of Bytes, change size to suit your needs
short bit1 ;
#INT_SSP NOCLEAR
void ssp_interupt (void)
clear_interrupt(int_SSP);
state = i2c_isr_state();
if(state < 0x80) //le maitre est entrain d'envoyé des donnée
if(state == 0) //premier octet réçue est l'adresse de l'esclave
{ // output_high(LED);
if(state == 1) //second octet réçue est l'adresse
address = i2c_read();
if(state == 2) //troisieme octet reçu est la donnée
*( (int8* )( &buffer[address + (state-2)]) ) = i2c_read();
output_high(LED);
bit1= true;
if(state == 0x80) //master is requesting data
i2c_write (buffer[address]); //send requested data
set_tris_c(0xFF);
bit1 = false;
enable_interrupts(INT_SSP); //enable I2C interrupts
buffer[0x00] = 0b10000000;
buffer[0x01] = 0b10000001;
buffer[0x02] = 0b01000010;
buffer[0x03] = 0b01000011;
buffer[0x04] = 0b10000000;
buffer[0x05] = 0b10000001;
buffer[0x06] = 0b01000010;
buffer[0x07] = 0b01000011;
delay_ms(10);
printf(lcd_putc,"\fcommunication I2C\n");//
printf(lcd_putc,"val : ");
if(bit1) // attend la donnée
lcd_gotoxy(9,2);
printf(lcd_putc,"%u ",buffer[address]); //Lu
bit1=false;
} | thank you |
Posted: Mon Feb 23, 2009 3:08 am |
Haven't looked at your code.
The PIC I2C hardware, _only_ supports 8bit transfers.
However the answer is that you can't send a 16bit value, as _one_ operation. Intead you send the two bytes that make up this value, one after the other.
Look at the make8 function (which allows you to access the separate bytes), and the make16 function (which allows you to put the two bytes back together to make a 16bit value.
A search here will find _hundreds_ of examples, dealing with the same problem over many different transfer media (RS232, I2C etc.).
Posted: Mon Feb 23, 2009 5:11 am |
Thank you to reply me:
i see what do you mean : i already try , but it send send some value , not exactelly what i send , and i don't realy know , if i code it correctelly. just look after.
master :
#include <16F883.h>
#device ADC=10
#define LED PIN_B4
#define t 0x08
int16 val,val1,val2,val3;
void envoie_i2c(BYTE end_disp, BYTE adr, int16 data )
i2c_write( data>>8 ); //envoie la donnée
i2c_write( data ); //envoie la donnée
nb1= data >> 8;
i2c_write( nb1 ); //envoie la donnée
i2c_write( *((int8*)(&data)+0) ); //envoie la donnée
i2c_write( *((int8*)(&data)+1) ); //envoie la donnée
val = 2000;
val1 = 1550;
val2 = 2300;
val3 = 455;
output_high(LED);
delay_ms( 500);
output_low(LED);
output_high(LED);
output_low(LED);
output_high(LED);
output_low(LED);
slave :
#include <16F877.h>
#device adc=10
#FUSES XT //
#define LED PIN_B3
int8 state, address ; // address and array of Bytes, change size to suit your needs
int16 buffer[0x08];
short bit1 ;
#INT_SSP NOCLEAR
if(state == 3) //troisieme octet reçu est la donnée
*( (int8* )( & buffer[address + (state-2) ]) )= i2c_read();
output_high(LED);
bit1= true;
set_tris_c(0xFF);
bit1 = false;
delay_ms(10);
lcd_gotoxy(9,2);
bit1=false;
